oil out new hg #887455 05/26/08 08:17 PM
mgd4me Offline OP
just put the new hg on. tourqued everything down to specs..turned the engine over to remove the old oil and water from block. while doing so, we noticed a masive oil leak coming from bewteen the head and block...head was shaved 12 ths..block none..cleaned all the old gasked meteral from block...block looked good...the hg i used is "multi layered" from *****. engs...... what i was thinking is a bad hg or i missed some old gasket meterial on the block...i noticed the top and bottom layer on the gasket were loose...dont remeber just where though....should i call for a new gasket, or just check the block and clean it again?....the truck is a 94 w/88 long block..94 intake..i had no leakes before the hg change. we even drove the truck around the yard..never over heating it...any ideas?...please ??
94 ex cab 3" body...33" bfgs... 1 roll over..stocker
http://www.youtube.com/watch?v=tYlDedAt96Y
Re: oil out new hg [Re: mgd4me] #887456 05/26/08 09:03 PM
toyrunner Offline
Did you ensure the dowel holes were deep enough for the head to sit flat after milling? This would be a reason for not seating well.
Hopefully that is not the issue cuz now that the head is torqued down, that would warp it good <img src="/forums/images/graemlins/frown.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: oil out new hg [Re: mgd4me] #887457 05/28/08 07:14 PM
dcg9381 Offline
Dowels are a good guess, as is the height of the front cover.
The other critical issue is tightening the head bolts in the right order - from the center outwards.
22REturbo.net
1988 4Runner
Re: oil out new hg [Re: mgd4me] #887458 05/30/08 04:42 AM
yota4runna Offline
Did you clean EVERYTHING out of the head bolt holes in the block? Did you use carb spray with the sprayer straw down the hole, followed by compressed air? If not, you may have hydraulic locked the head bolts on oil or anti-freeze in the bottom of the bolt holes, giving you false torque readings. Bolt holes MUST be clean, and head bolts MUST be lightly lubed on the threads and under the heads.
Re: oil out new hg [Re: yota4runna] #887459 06/03/08 05:49 PM
mgd4me Offline OP
yes i did all that...thats the only reason i think its the hg..or the dowel...i cant think of any thing else..and i didnt do anything to the block..
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6070 MB (Peak: 0.6720 MB) Data Comp: Off Server Time: 2026-10-22 07:38:56 UTC
