Re: Need Help--Brake Bleeding [Re: 67shagster] #887485 05/28/08 01:36 PM
missouriman Offline
I use a 60cc syringe and a tube to do mine.
the grease helps seal the bleeder.
and I can do it alone.
yeh these little tricks are gold when you have to do something for the first time.
Re: Need Help--Brake Bleeding [Re: missouriman] #887486 05/28/08 03:11 PM
RatLabGuy Offline
X10 (or whatever) on the vacuum bleeders being very finicky!
However, after trying amny tricks, the one that works the best BY FAR is to take out the bleeder valve altogether, and wrap the threads in YELLOW plumbers Teflon tape. Get a good several wraps.
Yo ureally should use the yellow stuff b/c it is designed for oil-based fluids. Brake fuid isn't really oil based, but will very quickly disolve the standard white teflon.
Anyhow, pull out the valve, wrap it, and stick it back in. Just be prepared to work fast b/c it wil ldrip like a mofo while you have that thing out!
This seriously decreases the amount of bubbles.
I'm with Roger, I crank the vacuum up to like 25-30 bars so the hose is nearly collapsed, THEN open it up just a hair.
1 vacuum tool tank = time to refill the MC.
Question Reality.
Re: Need Help--Brake Bleeding [Re: RatLabGuy] #887487 05/30/08 05:45 AM
6
67shagster Offline OP
Thanks for all the help. I got brakes again! Good thing there is a "4x4Wire".....saved me again. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.062s Queries: 16 (0.007s) Memory: 0.5993 MB (Peak: 0.6694 MB) Data Comp: Off Server Time: 2026-10-24 13:10:04 UTC
