brake #887511 05/27/08 04:12 AM
A
AkFordMan Offline OP
replaced master cylinder on 90 montero, bleed brake line of air. Still have to pump pedal to get good feel and stopping . No leaks, no air in lines. what up? Powerboaster? <img src="/forums/images/graemlins/confused.gif" alt="" /> thank for any help in advance
Re: brake [Re: AkFordMan] #887512 05/27/08 04:21 AM
ryany Offline
If your new master cylinder is not leaking past it's seals, then there's either still air in the lines or your rear brakes are way out of adjustment.
95 Montero SR
Re: brake [Re: AkFordMan] #887513 05/27/08 08:47 AM
worn/weak soft lines?
Re: brake [Re: AkFordMan] #887514 05/27/08 10:10 AM
sparkem Offline
Did you bleed the MC of air before putting it on?
Re: brake [Re: sparkem] #887515 05/27/08 11:12 AM
Y
yankneck696 Offline
Seconded on bleeding the master...
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: brake [Re: sparkem] #887516 05/27/08 02:01 PM
hazy_daze Offline
Thirded on the bench bleed question...
Re: brake [Re: yankneck696] #887517 05/27/08 02:03 PM
The FSM also talks about adjusting the pushrod between the piston and the booster. No experience myself here, but it would make sense that if it is out, there would be some sort of difference in pedal feel...?
Re: brake [Re: hazy_daze] #887518 05/27/08 03:11 PM
Mad_Scientist Offline
Yup, gotta bench bleed it first, like 'the others' said <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: brake [Re: sparkem] #887519 05/27/08 04:09 PM
Yup... that too. (Just in case you're not clear on that <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />)
Re: brake [Re: off-roader] #887520 05/27/08 09:53 PM
A
Will, first I want to say thanks for all the great advice! The m/c was bench bleed before I put it on and again this morning. I pulled and bleedit again,install it,bleed line to the wheels. Also check rear drum adjustment. Guess what? It was fine. Again THANKS for all your wisdom!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6333 MB (Peak: 0.7402 MB) Data Comp: Off Server Time: 2026-06-17 11:43:29 UTC
