CV Boot Replacement #887764 05/28/08 07:07 AM
F
Flannelman Offline OP
So I got everything torn into to fix a cv boot and I was having trouble getting the axle out so I slipped off the end CV half for more free play. I forgot to make any match marks on it per the manual am I going to be sorry now? Also every post I read it sounds like it shouldn't be hard to get the axle out with the axle where I am at but even with a jack under the A-Arm I still and not getting enough clearance to slide it out. I'm going to loosen the torsion bar tomorrow to get the angle but if there is another way.....
Thanks
1997 T-100 100k and counting Green
5spd 4x4 Ext Cab isr mod Aisin Manual hubs
Re: CV Boot Replacement [Re: Flannelman] #887765 05/28/08 07:40 AM
kewlynx Offline
I know changing these is a bit different than the early Toy IFS systems. Did you happen to read this?
http://www.4x4wire.com/toyota/maintenance/cv_axle/
On the axle, compare it to your other side to wag your match marks.
**ubi apis- ibi salus**
Re: CV Boot Replacement [Re: Flannelman] #887766 05/28/08 07:41 AM
E
eleet Offline
I didnt have to mess with the torsion bars.
If you jack up the a arm you should be able to move the axle off the diff. Then swing that end by the sway bar and pull it out of the steering knuckle.
I dont remember if I had to take the sway bar off for clearance reasons but I did take it off.
97 T100 4x4
97 328i
95 540i restoration project
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5951 MB (Peak: 0.6485 MB) Data Comp: Off Server Time: 2026-06-07 06:00:41 UTC
