00 Isuzu Rodeo Engine Problems.....Any Help??? #887866 05/28/08 09:59 PM
Isuzukid Offline OP
Hello Everyone,
I haven't been on here that much because I've been so busy with work. But now I need everyone's help again....
My 2000 Rodeo has been giving me problems as of late. When I try to start the car (especially in the mornings) it does not start. The accessories turn on, but it car won't turn over and it just makes a "click" "click" sound. It does not sound like a bad starter type sound. Just no sound at all, except the clicking. After trying to start the car about 5 to 6 times, it will eventually start. What could it be???
I am also experiencing another problem. The other day, I pulled into a gas station and put my car into park, The engine turned off by itself before I got to turn it off. It just shut down. And another time, I was in reverse backing out of the driveway, and it too just turned off. I restarted the car and it started up just fine.
Does anyone know what the problem could be? I don't have enough money to buy a new car, so this gas guzzler is my daily driver and I would like to fix the problem before I get left stranded somewhere. Thanks in Advance...
Re: 00 Isuzu Rodeo Engine Problems.....Any Help??? [Re: Isuzukid] #887867 05/29/08 11:01 PM
slappy Offline
I'd put money on it that it's your starter contacts that are worn. You don't need a new starter, just the brass contacts that go in it.
I did a post on here a while back on how to do it. Starter Removal Link
As for the sudden dying, perhaps a fuel cutoff or lack of air? I think you're gonna need to see it do a few more times before you can really figure out what's going on.
-john
99 Rodeo 3.2L 4WD
Re: 00 Isuzu Rodeo Engine Problems.....Any Help??? [Re: slappy] #887868 05/30/08 05:12 AM
Jeff Mason Offline
Although unlikely, a sudden dying could be related to fuel starvation. IIRC the ECM senses low fuel pressure and will shut off the engine. For $10 and 20 minutes, it is pretty cheap insurance to change the filter...
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: 00 Isuzu Rodeo Engine Problems.....Any Help??? [Re: Jeff Mason] #887869 06/02/08 05:25 AM
mr_spicoli Offline
Mine was shutting off periodically like you describe and a FPR kit from Jerry fixed the problem.
2000 Rodeo LSE
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6030 MB (Peak: 0.6603 MB) Data Comp: Off Server Time: 2026-07-16 03:42:35 UTC
