WHITE SMOKE AND SOUNDS LIKE A ROD #887870 05/28/08 10:08 PM
drtydzl Offline OP
i just took my truck in for its biyearly inspection and i was told it would not pass inspection for emissions the guy said dont worry i can fix it i had a lot of black smoke now i have no black smoke but some greyish white smoke and if i go over 1200 rpm the truck sounds like it is going to throw the rods also no water,antifreeze or fuel in the oil and no fluids are low or leaking any ideas. could he have adjusted the injection pump and now im getting next to no fuel someone help please 2.5L in dier need of help
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED
1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW
CURRENTLY LOCATED IN JAPAN
Re: WHITE SMOKE AND SOUNDS LIKE A ROD [Re: drtydzl] #887871 05/30/08 10:21 PM
bae146 Offline
take it back and have him un fix it!!!!
Re: WHITE SMOKE AND SOUNDS LIKE A ROD [Re: bae146] #887872 05/31/08 06:29 AM
drtydzl Offline OP
i took it back played 20 questions about what oils i use fuels bla bla bla and he said all he had to do to get it to stop smoking and knocking was unplug the vacume line from the egr valve that i already blocked off on the inside i think he did something and did not want to tell me but its back in good order now well got to put in my gauges and lift hoping to fit 35x10.5x15 super swamper boggers
Re: WHITE SMOKE AND SOUNDS LIKE A ROD [Re: drtydzl] #887873 06/11/08 06:36 AM
asmTdi Offline
had the same problem in mine, had to do diesel pump timing..more or less fuel is bad..engine heats, might crack the head..
1993 Pajero Xp LWB 2.5TDiC
Re: WHITE SMOKE AND SOUNDS LIKE A ROD [Re: asmTdi] #887874 06/12/08 03:40 AM
drtydzl Offline OP
WELL I TOOK IT BACK HE HAD IT OVER NIGHT HE SAID HE UNPLUGGED THE EGR VALVE BUT I BLOCKED IT OFF ALREADY SO I THINK HE DID SOMETHING ELSE JUST NOT SURE WHAT WELL ITS RUNNING GOOD NOW
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6048 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-06-21 13:39:48 UTC
