1998 isuzu rodeo 4x4 5 sp. What tranny is in this truck? #887875 05/28/08 10:58 PM
sasnydley Offline OP
We are thinking of doing the rear main seal and clutch and are not sure which trans is in truck? # on tranny- 84157329. I"m guessing it's the MUA? but don't how to Ident diff between Borg warner or other. Help?
Re: 1998 isuzu rodeo 4x4 5 sp. What tranny is in this truck? [Re: sasnydley] #887876 05/29/08 10:57 PM
slappy Offline
IIRC, it's an Isuzu made MUA. Someone can chime in if I'm wrong.
-john
99 Rodeo 3.2L 4WD
Re: 1998 isuzu rodeo 4x4 5 sp. What tranny is in this truck? [Re: sasnydley] #887877 05/30/08 04:42 AM
JLEMOND Offline
IF IT HAS VERY MANY MILES ON IT IT DEFINATELY WONT BE AN ORIGINAL BORG WARNER ,, ,,,,, YOU HAVE AN MUA THAT IS ALL THAT WAS EVER USED IN AN ISUZU 4X4, AFTER 88 NO EXCEPTION , UNTILL 98 TROOPER ONLY WENT TO THE ASIN WARNER , JERRY
Re: 1998 isuzu rodeo 4x4 5 sp. What tranny is in this truck? [Re: JLEMOND] #887878 05/30/08 02:44 PM
Thanks. I figured. The problem is - The shops want to charge a large amt money to do rear main seal. $800.00. The clutch was more. Truck is in great shape other than this. I have never done a clutch but i did my own head on my monty and have put engines in in the past. Is this something a back yard mechanic can do? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: 1998 isuzu rodeo 4x4 5 sp. What tranny is in this truck? [Re: sasnydley] #887879 05/31/08 03:46 PM
JLEMOND Offline
CERTAINLY DOABLE , JUST RENT A FLOOR STYLE TRANS JACK, IT IS A LOT SAFER THAN A REGULAR FLOOR JACK BUT CAN BE DONE WITH A COUPLE OF EXTRA HANDS , THAT TRANNY IS VERY HEAVY, A COMPLETE CLUTCH ASSY BOUGHT LOCAL AND YOU CAN SAVE YOURSELF CLOSE TO 500 JUST BE CAREFULL AND WHEN REMOVING THE TRANS CASE BOLTS TO ENG BLOCK MARK EACH BOLT WHERE IT GOES , THERE ARE 3-4 DIFF LENGTHS AND YOU CAN DAMAGE TH E BLOCK WITH THE WRONG BOLTS JERRY
Re: 1998 isuzu rodeo 4x4 5 sp. What tranny is in this truck? [Re: JLEMOND] #887880 06/01/08 02:11 AM
What do you mean complete clutch assembly? I would have my Nephew buy the jack <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 1998 isuzu rodeo 4x4 5 sp. What tranny is in this truck? [Re: sasnydley] #887881 06/01/08 03:11 AM
mlclark Offline
Isuzu Moderator
To do a clutch, you need the clutch disk, the pressure plate, the throwout bearing and a pilot bearing. This is what comes in a "clutch kit".
You should also allow for time to have the flywheel surfaced.
Michael
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6131 MB (Peak: 0.6912 MB) Data Comp: Off Server Time: 2026-07-09 22:40:26 UTC
