Chrome Strip Coming Off #888068 05/30/08 06:14 AM
garym Offline OP
That trim around the wheel wells is coming off on the driver's side, probably because that is the side that gets the direct sun when parked in the driveway. Can you glue the sections that are coming off back, should I peel the whole thing off and start new, and is there something that takes the adhesive tape off if I do? I know that 3M double sided trim tape works good but what if it is just a few spots coming loose? Was the trim factory, or aftermarket. I bought the truck used. Thanks.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Chrome Trip Coming Off [Re: garym] #888069 05/30/08 07:43 AM
adam Offline
My experience with reattaching that type of thing in situ hasn't been great. It always ends up looking patched. Be neat with the glue, and it should come out okay, though. If you remove the whole thing the Goo Gone citrus spray and a credit card will take the adhesive off pretty easily without ruining the paint.
~Adam
Re: Chrome Trip Coming Off [Re: adam] #888070 05/30/08 08:38 AM
CJMT100 Offline
I glued mine back on with 3m trim adhesive, its that yellow trim goop glue.
Re: Chrome Trip Coming Off [Re: garym] #888071 05/30/08 11:18 AM
foxtrapper Offline
Take a good look at yours, mine is screwed on, from the factory. Replacement pieces are available (for mine at least) from the dealerships.
'97 T-100 SR5
Re: Chrome Trip Coming Off [Re: foxtrapper] #888072 06/03/08 08:29 PM
garym Offline OP
Mine is aftermarket. Did dig through some receipts and found the original bill. I will see if the guy warrantees it for life. Thanks for all the hints.
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6040 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-05-29 23:51:18 UTC
