97 rodeo battery connected backwards #888261 05/31/08 09:49 PM
SOURCE7769 Offline OP
headlights turn on and the dash instrument lights come on but doesnt crank over and the door locks, windows dont work any idea the extent of damage done? ecu fryed? where do i start
97 rodeo 3.2 4wd
Re: 97 rodeo battery connected backwards [Re: SOURCE7769] #888262 05/31/08 10:50 PM
Van Offline
I would start by checking all the fuses.
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: 97 rodeo battery connected backwards [Re: Van] #888263 06/01/08 06:33 PM
main fusible link blew ,i changed it the car starts now but the battery light comes on and the voltmeter i tested it with reads 12.1 ? would the alternator have went , maybe the regulator?
97 rodeo 3.2 4wd
Re: 97 rodeo battery connected backwards [Re: SOURCE7769] #888264 06/01/08 07:01 PM
also lights do not dim when i put them on along with hi beams the battery meter on the dash doesnt dip, maybe the battery drained from being on backwards?
97 rodeo 3.2 4wd
Re: 97 rodeo battery connected backwards [Re: SOURCE7769] #888265 06/02/08 01:07 PM
RobG Offline
I blew out the main fusable link during a jumpstart once... thought I might have fried the ECU as well, but turned out to be the ignition control module (circuit board that sits under the coil packs)... you may want to check this out.
here's my thread:
3.2L replaced main fusable link but still won't start?
-Rob
Re: 97 rodeo battery connected backwards [Re: RobG] #888266 06/02/08 02:49 PM
no mine starts but the battery light is on and the battery read 12.1v with the engine off and with the engine on , im wondering if the alternator is bad or if there is a fuse or diode that may have blew on the alternator
97 rodeo 3.2 4wd
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6094 MB (Peak: 0.6794 MB) Data Comp: Off Server Time: 2026-05-29 16:16:00 UTC
