Brake warning light stays on, then goes off then comes on again...? #888313 06/01/08 07:30 AM
bergie Offline OP
The brake warning light in my 1990 Pajero LWB auto stays on in the morning after I start up and drive off. It's not the handbrake because if I leave the handbrake off overnight, the light is still on when starting up in the morning. I took the sensor wire off the brake booster, and earthed it but that makes no difference. When I take the low level sensor connection off the master cylinder the light goes out, and comes on again when I connect it up again. The master cylinder is full of fluid.
During stop start driving during the day the warning light goes off, but sometimes comes on again if I brake.
Any Ideas anyone? I've checked the booster in the normal way and it seems fine. Braking seems normal as well. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Brake warning light stays on, then goes off then comes on again...? [Re: bergie] #888314 06/01/08 07:37 AM
StockRaider Offline
is the float in the reservoir stuck?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Brake warning light stays on, then goes off then comes on again...? [Re: StockRaider] #888315 06/01/08 10:00 AM
bergie Offline OP
I don't think so, but I'll check in the morning. Thanks, Bergie
Re: Brake warning light stays on, then goes off then comes on again...? [Re: bergie] #888316 06/01/08 12:51 PM
FrankR Offline
If you can't find anything wrong with the fluid level, fluid reservoir switch or parking brake switch, check the alternator.
Frank
Re: Brake warning light stays on, then goes off then comes on again...? [Re: bergie] #888317 06/01/08 01:09 PM
Steve Nichols Offline
On POC(uk) this has popped up an a number of occasions, usually the float switch but these are sensative to small drops in fluid level & just adding a small amount of fluid will solve the problem.
I'll go with fluid level, as you say that the light goes off during stop/start driving which will heat-up the fluid & it expands a little.
SteveN <img src="/forums/images/graemlins/wink.gif" alt="" />
Shogun (Pajero/Montero) 3.0L V6 12valve LWB Auto 1993
142k miles.
Dual Bouncy Seats
Totally stock
c/w Diff lock
now sold
Re: Brake warning light stays on, then goes off then comes on again...? [Re: StockRaider] #888318 06/01/08 06:12 PM
Grasscat Offline
Mine sticks sometime also and it's been the float in the reservoir. I think I need to clean the brake fluid system as it look dirty.
Michael j
TreadLightly! Trainer
Re: Brake warning light stays on, then goes off then comes on again...? [Re: Grasscat] #888319 06/02/08 10:48 AM
bergie Offline OP
After startup this morning I poked the float in the master cylinder and the brake warning light went out. DUHHH! Why didn't I think of that. Thanks everyone. Bergie.
Re: Brake warning light stays on, then goes off then comes on again...? [Re: bergie] #888320 06/02/08 03:22 PM
Crops Offline
Can you post a photo of how you did this so other folks can follow your lead? Thanks!
R.
89 Raider V6
95 SR Montero
Re: Brake warning light stays on, then goes off then comes on again...? [Re: Crops] #888321 06/02/08 04:04 PM
hazy_daze Offline
You take off the lid on the master cylinder and poke your finger down in the reservoir. All there is too it.
Re: Brake warning light stays on, then goes off then comes on again...? [Re: hazy_daze] #888322 06/02/08 05:25 PM
Grasscat Offline
What "hazy-daze" said except, poke your finger on the float, in the reservoir. Just dislodge it. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6401 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-05-29 17:25:12 UTC
