TBI bonnet Vaccum and breather hose reworking #888417 06/02/08 10:10 AM
Nick Muzzio Offline OP
I am in the process of adding a turbo Bonnet to my snorkel system. I was kind of curious what I should be doing with a couple things now. I have my MAP sensor that was attached to the old air cleaner pan as well as a valve cover vacuum hose. I assume the MAP sensor will be fine just hanging there but I'm not sure what to do with the Valve cover hose. I've seen what looks like just valve cover breather caps and such, would that work for me? I thought the hose was just there to re-burn any fumes coming out of your engine? Any Ideas?
Thanks
91 Trooper LS, 5 Speed Manual
3.4L Engine w/4.3L Throttle Body
Snorkel, 31" Pro Comp MT Tires, 2"lift,
ProComp ES9000 shocks and steering stabilizer
http://members.cardomain.com/sun_thief
Re: TBI bonnet Vaccum and breather hose reworking [Re: Nick Muzzio] #888418 06/10/08 02:34 AM
OK did some research on how the PCV system works and I guess the drivers side valve cover just needs a breather to pull air from. The breathers usually have little filters on them because the stock one pulls from the air cleaner and is already filtered. The passengers side valve cover has the actual PCV valve and pulls air out to be put back into the intake to be burned.
Do I have that about right? Why have I seen some vehicles that appear to just have breathers on both valve covers and no PCV at all? Also why do some of the breather kits have a shield on them? Which side do you point the shield, towards the engine or away from the engine?
Thanks for any help.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5903 MB (Peak: 0.6383 MB) Data Comp: Off Server Time: 2026-05-30 01:18:15 UTC
