SAFE BOOST LEVELS #888419 06/02/08 12:11 PM
drtydzl Offline OP
HEY IM BUMPING THE BOOST ON MY 89 2.5L IM SETTING AT 15 PSI RIGHT NOW ANY IDEAS HOW HIGH I CAN GO SAFELY I WOULD LIKE 20 PSI TO GO WITH THE PROPANE INJECTION KIT I AM GETTING READY TO INSTALL
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED
1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW
CURRENTLY LOCATED IN JAPAN
Re: SAFE BOOST LEVELS [Re: drtydzl] #888420 06/12/08 05:22 AM
rockrenegade Offline
20lbs would probably be the max on a stock 4d55 or 4d56.
84' twin turbo diesel PowerRam 50, Rockwells, 4 linked, 47" LTB's, dual cases
Re: SAFE BOOST LEVELS [Re: drtydzl] #888421 06/13/08 12:34 AM
PHIL_ Offline
You'll get much better responses to your posts if you turn off your "CAPS LOCK". It is considered shouting on most forums, and is poor etiquette.
Thanks
Phil
Re: SAFE BOOST LEVELS [Re: PHIL_] #888422 06/13/08 04:23 AM
drtydzl Offline OP
sorry i just tend to type with the capslock on i post in my spare time at work and my english is horrible so with all caps i dont worry about punctuation sorry if i offended you that was in no way shape or form my intention and these forums and posts are kind of new to me this is the first time i have been unable to find good help with my own projects as i am in japan and an american and most people tell me i am wasting my time with a pajero to start with
Re: SAFE BOOST LEVELS [Re: drtydzl] #888423 06/13/08 05:49 AM
PHIL_ Offline
No offense taken or meant, figured you didn't know: lots of folks don't. And your English is fine. Punctuation? Well, I'm a teacher, so maybe I'm just picky? <img src="/forums/images/graemlins/lol.gif" alt="" />
Wasting time with a Paj? Well, in that case I've been wasting time for the last 13 years. Heheh! If its a waste of time, I can't think of a better way to waste it! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: SAFE BOOST LEVELS [Re: PHIL_] #888424 06/13/08 08:00 AM
4ePajero Offline
I would not increase the boost on ANY TD by more than 10% of the spec.
Even then you will be well advised to fit an EGT gauge to keep an eye on combustion temperatures.
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: SAFE BOOST LEVELS [Re: 4ePajero] #888425 06/13/08 11:09 AM
drtydzl Offline OP
Well at 17PSI boost max currently. Running 80-100 KPH i sit around 700 degrees farenthieght if i pull a big hill i hit around 1000-1100 degrees i was always taught anything under 1200 degrees was good and if you are pulling a sled or something
1500-1800 was ok for that short duration i have a 2001 F250 in the US i use for sled pulls and stoplight racing
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6196 MB (Peak: 0.6941 MB) Data Comp: Off Server Time: 2026-11-03 13:38:27 UTC
