'94 3.5L SR transfer case about to go bye bye!
#888442
06/02/08 04:37 PM
Well, I'm getting ready to go camping and I was wondering if anyone has had their t-case go bad. I'm trying to figure how long I can go till I need to replace it. There is kind of a constant vibration at higher speeds and at low speeds a metallic clicking sound (random). There is also a lot of play where the driveshaft enters the t-case. (not the universals) The gear lube looks good. Thanks for the thoughts! <img src="/forums/images/graemlins/confused.gif" alt="" />
1994 Montero SR Divide Colorado
Re: '94 3.5L SR transfer case about to go bye bye!
[Re: reknawj]
#888443
06/02/08 07:59 PM
A lot of play were the yoke enters the t-case may be caused by the yoke and have nothing to do with the t-case. A sloppy yoke can also cause vibration and strange noises. I'd check that first before jumping into a t-case rebuild.
'97 Montero Sport LS 5-Speed 3.5L conversion SAS Dana 44s & ARBs, 35" Yoko Geolandar M/Ts NP231 B4R doubler/Terra Low231/RP 5.38 229:1 '99 Montero Sport Limited 4WD SAS 3-link project '03 Montero Sport Limited AWD '97 Montero Sport LS 5-Speed 4WD
[Re: ES_97Sport]
#888444
06/04/08 05:37 AM
[Re: reknawj]
#888445
06/04/08 07:03 AM
a check engine light maybe <img src="/forums/images/graemlins/confused.gif" alt="" /> One of the many signs <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PHP: 7.4.33 Page Time: 0.027s Queries: 15 (0.022s) Memory: 0.6029 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-11-04 19:59:58 UTCValid HTML 5 and Valid CSS
