'94 3.5L SR transfer case about to go bye bye! #888442 06/02/08 04:37 PM
reknawj Offline OP
Well, I'm getting ready to go camping and I was wondering if anyone has had their t-case go bad. I'm trying to figure how long I can go till I need to replace it. There is kind of a constant vibration at higher speeds and at low speeds a metallic clicking sound (random).
There is also a lot of play where the driveshaft enters the t-case. (not the universals)
The gear lube looks good.
Thanks for the thoughts! <img src="/forums/images/graemlins/confused.gif" alt="" />
1994 Montero SR
Divide Colorado
Re: '94 3.5L SR transfer case about to go bye bye! [Re: reknawj] #888443 06/02/08 07:59 PM
ES_97Sport Offline
A lot of play were the yoke enters the t-case may be caused by the yoke and have nothing to do with the t-case. A sloppy yoke can also cause vibration and strange noises. I'd check that first before jumping into a t-case rebuild.
Re: '94 3.5L SR transfer case about to go bye bye! [Re: ES_97Sport] #888444 06/04/08 05:37 AM
reknawj Offline OP
I'll check it thanks!
1994 Montero SR
Divide Colorado
Re: '94 3.5L SR transfer case about to go bye bye! [Re: reknawj] #888445 06/04/08 07:03 AM
Angelo Offline
a check engine light maybe <img src="/forums/images/graemlins/confused.gif" alt="" /> One of the many signs <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6036 MB (Peak: 0.6592 MB) Data Comp: Off Server Time: 2026-05-29 15:00:47 UTC
