electric fan and radiator removal??? #888917 06/04/08 01:09 PM
menotthat Offline OP
Out of all you guys and girls, how many have been able to remove the old fan and shroud without removing the radiator?
Is it possible? If not whats stopping it.
Need info before I get into it..Time is limited once I start.
Thanks
97 sportage, mostly stock apart from king springs front and rear, monroe shocks, k&n filter, pioneer mp3 cd, rampage 2x 10"subs and rampage amp.
Re: electric fan and radiator removal??? [Re: menotthat] #888918 06/04/08 04:33 PM
bombardj1 Offline
I have a 2001 and it is easy, remove air-intake, loosen belt alt, remove the bolts from shroud to the rad, remove nuts from clutch fan to pulley, pull clutch forward to clear studs, work both shroud and clutch fan assembly up and out.
But you state eletric fan are you talking about the fan for the A/C ? or are you installing a Eletric fan ?
John
Re: electric fan and radiator removal??? [Re: menotthat] #888919 06/04/08 04:39 PM
Delarey Offline
Nope. I dont think its possible. I recently removed my car's fan and fitted an electric one. Had to remove the radiator, but it was necessary as I had to make and fit brackets to hold the fan. Got rid of the shroud as well.Was'nt such a big job and worth the effort and scoring on consumption as well.
Re: electric fan and radiator removal??? [Re: bombardj1] #888920 06/04/08 11:07 PM
logansportage Offline
I did it the same way as bombardj1 and IT IS POSSIBLE!!!
Re: electric fan and radiator removal??? [Re: logansportage] #888921 06/05/08 03:48 AM
Everet Offline
Me three!!! <img src="/forums/images/graemlins/pfft.gif" alt="" />
If you look at my 3 row radiator post you can install the electric fan in the shroud and when it was initially done, I didn't remove the radiator. Electric fan works great installed in the hole of the shroud. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: electric fan and radiator removal??? [Re: Everet] #888922 06/06/08 08:41 AM
O
oul053 Offline
i work on these things most days and its possible
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: electric fan and radiator removal??? [Re: oul053] #888923 06/07/08 12:27 AM
DennisThompson Offline
I have changed my timing belt without removing the radiator, I'm sure the fan had to come out for that <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />.
Dennis
Re: electric fan and radiator removal??? [Re: DennisThompson] #888924 06/10/08 01:38 PM
thanks guys. i thought it was possible. now just need some time to get the old fan out, and throw in a new electric one.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6218 MB (Peak: 0.7043 MB) Data Comp: Off Server Time: 2026-07-09 16:13:05 UTC
