00 Amigo has thumps when stopping and taking off. #888997 06/04/08 09:15 PM
ralequin6ra Offline OP
Hello
I would love any kind of advice. Waiting at a traffic light and then taking foot off brake and pressing on gas, within the first foot of takeoff I feel a small thump. The same goes for if I was to brake quickly. After coming to complete stop there is again the same thump. It doesn't happen any other time than takeoff and coming to complete stop. I thought the thumps came from tranny, but aamco said no. The engine is a 3.6 6cyl and runs perfectly. I just don't know where these thumps are coming from. Could if be suspension? Someone mentioned that maybe the body is sliding on the chassis. Is that possible? Has anyone ever heard of this problem? thanks.
Re: 00 Amigo has thumps when stopping and taking off. [Re: ralequin6ra] #888998 06/05/08 04:02 PM
HCMP Offline
Couple of possibilities:
1. Check to make sure your jack hasn't come loose inside its compartment
2. http://isuzufaq.ibctech.ca/#faq9
3. Check that your body mount bolts are tight. The locations are.. front of frame, frame about where the front of the door is, frame behind where the door is, and at the rear of the frame.
Also, your engine is a 3.2 v6
good luck
Re: 00 Amigo has thumps when stopping and taking off. [Re: ralequin6ra] #888999 06/05/08 04:07 PM
pinoy99 Offline
sounds like a worn u-joint
Re: 00 Amigo has thumps when stopping and taking off. [Re: pinoy99] #889000 06/06/08 04:03 AM
U
US_Marshal Offline
How is the spare tire held in on that model?
Re: 00 Amigo has thumps when stopping and taking off. [Re: US_Marshal] #889001 06/06/08 05:35 AM
Jeff Mason Offline
spare tire is on the back door. I doubt the thump is from there. One other possibility is that the slip yoke needs to be greased - I'll look around for threads and try to post some here...
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: 00 Amigo has thumps when stopping and taking off. [Re: Jeff Mason] #889002 06/06/08 05:40 AM
Jeff Mason Offline
Found it. Read this:
http://www.4x4wire.com/forums/showf...ew=&sb=5&o=&vc=1
Slip yoke needs lube. Mines been that way for about 40,00 miles, maybe I will fix it this weekend... <img src="/forums/images/graemlins/smile.gif" alt="" />
Jeff Mason
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6088 MB (Peak: 0.6786 MB) Data Comp: Off Server Time: 2026-10-24 07:17:32 UTC
