Gen2 Body onto Gen1 Chassis? #889313 06/06/08 04:43 PM
4ePajero Offline OP
I am toying with an idea.
Can you gurus help me with the following:
1. Does the Gen2 LWB body fit straight onto the Gen1's LWB chassis ?
2. Do the seats and door panels from Gen1 LWB fit to the Gen2 LWB?
(bouncy seats' frames?)
Gerhard
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: Gen2 Body onto Gen1 Chassis? [Re: 4ePajero] #889314 06/06/08 06:05 PM
No, they are not the same wheelbase, the gen 2 is slightly longer.
Re: Gen2 Body onto Gen1 Chassis? [Re: 4ePajero] #889315 06/07/08 12:20 AM
sparkem Offline
Door panels are different. Not sure about the seat frame.
Why do you want to do the swap? Bad motor? Bad frame? Wreck?
Re: Gen2 Body onto Gen1 Chassis? [Re: sparkem] #889316 06/07/08 12:23 AM
Seat frames are different. Gen II is wider than a Gen I, too.
Re: Gen2 Body onto Gen1 Chassis? [Re: rxinhed] #889317 06/07/08 04:21 AM
Gen II seat base is also fitted to the floor, which isn't flat like a Gen I.
Re: Gen2 Body onto Gen1 Chassis? [Re: rxinhed] #889318 06/07/08 11:03 AM
4ePajero Offline OP
Sparkem,
No, I can get a good Gen2 body with a bad engine, and thought I would swop over to my chassis & drive train.
Since the Gen1 was never sold here, body parts are a problem, but not so for Gen2 onwards.
Thanks for all the replies, which leads me to believe my idea is a non-starter.
2" Lift
Front Runner Rack
Re: Gen2 Body onto Gen1 Chassis? [Re: 4ePajero] #889319 06/08/08 04:31 PM
Gen I body parts aren't the problem, it's just the shipping price to get them to you. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Gen2 Body onto Gen1 Chassis? [Re: 4ePajero] #889320 06/08/08 05:12 PM
What about swapping your engine into the Gen II?
Re: Gen2 Body onto Gen1 Chassis? [Re: MontyMcV] #889321 06/09/08 07:39 AM
4ePajero Offline OP
That is a lot of work! I had to do quite a bit of manufacturing on mountings, pipe work and drive shafts to make the Di-D fit in the Gen1.
It is possible, but I can't gather the enthusiasm to go through it again!
2" Lift
Front Runner Rack
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6292 MB (Peak: 0.7310 MB) Data Comp: Off Server Time: 2026-05-29 14:41:04 UTC
