'86 vibrations while coasting down hill. #889352 06/06/08 10:28 PM
A
AZcoma Offline OP
Took a couple of trips up to northern AZ the past month and I have this pretty significant vibration in the drivetrain when coasting down hills (letting off the throttle). Once I apply the throttle, it goes away. U joints have never been replaced but lubed religiously. 150k miles with 4" springs and 2" shackles. I have shims between the springs and the perch. Easy way to tell if it's the U-joints or the pinion bearing going south?
'86 4x4 SR5 22re 5" lift 35" BFG's and 5:29 gears.
'05 4x4 DC Tacoma TRD Sport
Re: '86 vibrations while coasting down hill. [Re: AZcoma] #889353 06/06/08 10:42 PM
4Crawler Offline
Check the u-joints, pinion flange and slip yoke for play. How? Grab ahold of the drive shaft and give it a tug. Also, check the pinion angle, could be it is a little too low:
- http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml#Measurements
Re: '86 vibrations while coasting down hill. [Re: 4Crawler] #889354 06/06/08 11:18 PM
A
AZcoma Offline OP
I'll be giving it the once over this wkend. I also have a digital angle finder that should help with the pinion angle verification.
Re: '86 vibrations while coasting down hill. [Re: AZcoma] #889355 06/07/08 01:17 AM
P
philly Offline
is it a vibration or a grinding vibration sound? mine does the same ***** i think its more of a grinding vibration in the tranny or tcase, no clue about it tho. gota figure that out so i can drive on the highway again, only does it past 50 mph <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: '86 vibrations while coasting down hill. [Re: philly] #889356 06/07/08 02:55 PM
E
Ezrider_92356 Offline
when you do the shake test on the u joints chock the tires and put it in newtral a load on the shafts can give the false indication of a good tight u joint, any play and they should be replaced.
Re: '86 vibrations while coasting down hill. [Re: Ezrider_92356] #889357 06/09/08 05:13 PM
A
AZcoma Offline OP
maybe my shims are in backwards?? I checked the U-joints and they are tight. Checked the angle and it appears that the diff is pointed up at the Transfer case. The shims in place have the wedge section in the rear which tips the diff up. Is this wrong?
Re: '86 vibrations while coasting down hill. [Re: AZcoma] #889358 06/09/08 05:19 PM
4Crawler Offline
Re: '86 vibrations while coasting down hill. [Re: 4Crawler] #889359 06/09/08 05:26 PM
A
AZcoma Offline OP
stock driveshaft of 86 Toy extra cab. It's a single.
Re: '86 vibrations while coasting down hill. [Re: AZcoma] #889360 06/09/08 09:14 PM
4Crawler Offline
With u-joints on both ends, you want the t-case and pinion flanges to end up nearly parallel:
- http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml#Single-Cardan-Measurements
Re: '86 vibrations while coasting down hill. [Re: 4Crawler] #889361 06/09/08 10:50 PM
A
AZcoma Offline OP
bummer! Just finished taking the shims out and the angles are closer but I'm still 6 degrees off between the two. I'll drive it for a bit and see if there is a reduction in the vibration. If not, I guess I'll be looking into some new shims.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6446 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-05-29 17:08:05 UTC
