Wiring the center gauge cluster - 1991 #889496 06/08/08 02:32 AM
dwehbie Offline OP
I have a 1991 montero. Found a center gauge cluster with a tilt meter, oil pressure gauge, and volt meter. I need to know how to wire it up. I know I need to buy an oil pressure sending unit. How do I wire the oil pressure gauge and volt meter?
1996 Toyota T100
Re: Wiring the center gauge cluster - 1991 [Re: dwehbie] #889497 06/09/08 07:15 AM
blinkerbox Offline
Look at your dash where the cluster will be positioned. You will see a plastic insert that you need to pop out. The connector will be located in there. You'll need to fish it out. Your Montero came pre-wired with that connector. I had to do the same things when I got my Montero. I fastened the cluster down with some sheet metal screws that had a washer and rubber washer. Good luck!
'91 RS, '93 SR
Re: Wiring the center gauge cluster - 1991 [Re: blinkerbox] #889498 06/09/08 11:53 AM
dwehbie Offline OP
Thanks, It worked. Now Just one more question. When I install the oil pressure sending unit, which wire do I use? Do I use the same one going to the oil pressure switch?
1996 Toyota T100
Re: Wiring the center gauge cluster - 1991 [Re: dwehbie] #889499 06/09/08 03:04 PM
blinkerbox Offline
Yep, use the same wire.
'91 RS, '93 SR
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5996 MB (Peak: 0.6553 MB) Data Comp: Off Server Time: 2026-06-23 01:15:11 UTC
