'79 Toyota 4x4 with Weber runs out of fuel at idle in 15 minutes #890006 06/11/08 12:41 AM
mollydawg Offline OP
My buddy in CO has a '79 20R 4x4. He recently put a 32/36 Weber on it. Seems to run fine down the road, but has never had it out for very long runs. He started it the other day to run it for a while as it had been sitting, it ran for 15 minutes at an idle and it shut down. The fuel filter had drained down. He thought it might be airlocked, removed the fuel line, reconnected it, started it back up, placed a stick on the gas pedal and ran it about 1500 rpm and it ran an hour before shutting down again. Fuel pump tested to 3.5 lbs, filled a can with gas with it so volume seemed to be ok too. Pump has about 60,000 miles on it(Toyota pump). Is it possible the Weber is creating an airlock under those conditions? He is not using any smog equipment on the truck.
HELP!
mike
'96 Taco 4x4 2.7 with 270,000 miles and climbing
Re: '79 Toyota 4x4 with Weber runs out of fuel at idle in 15 minutes [Re: mollydawg] #890007 06/11/08 02:14 AM
stock87 Offline
Did he put a fuel pressure regulator on? The factory pump actually puts out too much PSI for the Weber to handle. I seem to recall they like 3-5psi, and the factory pump puts out 7-9psi, but don't hold me to those numbers. I betcha that's the problem.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: '79 Toyota 4x4 with Weber runs out of fuel at idle in 15 minutes [Re: stock87] #890008 06/12/08 06:23 AM
No regulator that I know of, but he did test the pressure of the electric pump and it was around 3.5 psi. He claims some of the '79's had electric pumps, but not all.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5936 MB (Peak: 0.6471 MB) Data Comp: Off Server Time: 2026-07-16 07:37:13 UTC
