3.0 propane conversion - has anyone done this? #890200 06/11/08 09:11 PM
Bent_85 Offline OP
Hi
I know some have converted the 22R to propane but has anyone converted the 3.0. Where I am, the cost of propane is about 63cents/litre - which is a lot less than gasoline.
What I'm wondering about is the role of the computer and timing in the V6. Could you unplug the computer. Any thoughts are appreciated.
Thx
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: 3.0 propane conversion - has anyone done this? [Re: Bent_85] #890201 06/12/08 09:11 PM
chubbydude Offline
I was thinking the same thing and found this link. The kit looks fairly simple and it is priced reasonable as well, just no feedback or numbers from installs.
http://poweredbypropane.net/index.html
Re: 3.0 propane conversion - has anyone done this? [Re: Bent_85] #890202 06/13/08 04:12 AM
O
oldsub86 Offline
My understanding is that a propane conversion usually results in less power - not a good thing with a 3.0.
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: 3.0 propane conversion - has anyone done this? [Re: oldsub86] #890203 06/14/08 06:37 AM
dcg9381 Offline
You'll take a slight hit in power, may not be noticable.
I've been playing with the idea of dual-fueling. Not propane OR gas... But propane AND gas. Basically do a propane mixer setup to run intentionally lean and suppliment with gas - and tune the EFI for gas... Haven't seen anyone but diesels trying this setup.
22REturbo.net
1988 4Runner
Re: 3.0 propane conversion - has anyone done this? [Re: dcg9381] #890204 06/14/08 07:11 AM
chubbydude Offline
See the link below on the Vogas split fuel system:
http://www.fireemup.com/products.php
Some other links with some good info/kits:
http://www.technocarb.com/
http://cars.rasoenterprises.com/
Re: 3.0 propane conversion - has anyone done this? [Re: oldsub86] #890205 06/14/08 08:31 PM
OOP'S Offline
And it is with a 22r?
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 3.0 propane conversion - has anyone done this? [Re: oldsub86] #890206 06/15/08 03:08 AM
matts Offline
Propane has less energy per unit of fuel, but it has an equivalent octane of 105, so it's very suitable for a high compression piston upgrade or turbo-charging. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: 3.0 propane conversion - has anyone done this? [Re: matts] #890207 06/16/08 12:19 AM
brentox Offline
Propane: 91,690 btu/gallon
Gasoline: 110,250 btu/gallon
Diesel(#2 fuel oil): 142,800 btu/gallon
These conversions numbers may help. They represenst the amount of energy each fuel type contains per gallon. Its easy to see why and by how much that diesel engines get better gas mileage than a similar gasoline type. The problem now is that diesel has become so expensive to refine for the emmissions requirements that its mpg upside does not pay to the additional $ at the pump. The propane energy component is lower than gas or diesel. Is it cheap enough to make it viable? Based on the energy content numbers i would expect to see mpg suffer as well as engine hp output. It may be a good option if its cheap enough to run. If anyone pulls this off PLEASE, keep us posted <img src="/forums/images/graemlins/patriot.gif" alt="" />
92 Extended Cab 4x4, 3.0 5-Speed Scratched, Dented and Rusted.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6231 MB (Peak: 0.7053 MB) Data Comp: Off Server Time: 2026-10-22 07:39:32 UTC
