Re: Opinions on Raider/montero tire size
[Re: Bhealy]
#890230
06/13/08 08:01 PM
Les Schwab is so overpriced. <img src="/forums/images/graemlins/evil.gif" alt="" />
I bought and traded parts for the alloys I have (all 8) and bought some cheapy tires....all for around $500. Check out Craigslist, Pirate, and 4x4Wire classifieds, you're likely to find some good used tires for cheap. I ran 25k miles on a set of Pirate sourced tires for $80!
Even WalMart sells BFG all terrains for $125/each or so...
[Re: rxinhed]
#890231
06/13/08 08:05 PM
Les Schwab's AT's are 95 a piece and the wheels are 52....
87' Raider: off road package, rebuilt engine with (new) stock tires and alloy wheels but otherwise original.
[Re: Bhealy]
#890232
06/13/08 08:34 PM
i would go 33"s. i live near the canadian rockies and have a 2.6 in my unit. have no issues with the 33"s for driveability and they look bad <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
'09 Acura TSX Tech Package '05 Blazer (Company hauler) Retired '88 Bada$$ edition Raider (now owned by shadowgear)
[Re: Bhealy]
#890233
06/13/08 09:43 PM
Something like this: Pirate ad #1 Pirate ad #2 4x4wire ad (here) <img src="/forums/images/graemlins/shiner.gif" alt="" />
[Re: FrankR]
#890234
06/14/08 12:56 AM
Believe me, there is NO SUBSTITUTE FOR STUDDED TIRES ON ICE!! I live near Snoqualmie Pass (55 miles e/o Seattle). As you know we get a lot of deep snow, snowplow after-freeze, freeze thaw, crusty ice, ice storms etc., etc. During winter the conditions are always changing from hour to hour. Studless tires are a joke. So you'll need a second set of STUDDED tires & wheels for winter.
Your next consideration is whether or not you also need CHAINS. Chains require a lot of wheel-well clearance, so you couldn't use a big diameter tire if you do. You also need to decide how often you will be driving in DEEP snow. Narrow tires work better than wide in deep snow.
All things considered, I recommend a 235x75xR15 LT. Not too tall or wide and they still leave enough room for chains. Tread pattern is a personnal choice, but STUDDED TIRES ARE IMPORTANT.
Rich Smith
[Re: RichSmith]
#890235
06/14/08 01:37 AM
Under certain conditions maybe. Including those your way? There is no one in the Iceland contingency with narrow tires. Quite the opposite. They go to great lenghts to modify the sheet metal to fit the likes of 38X15.5 or such.
[Re: rxinhed]
#890236
11/07/10 09:51 PM
rxinhead.. did you need to lift your Raider in order to fit the 33"?
[Re: Montero84]
#890237
11/07/10 11:40 PM
rxinhead.. did you need to lift your Raider in order to fit the 33"? 2" BL, torqued torsion bars, & gen ii coil springs on my 89 v6. <img src="/forums/images/graemlins/kewl.gif" alt="" /> ![[Linked Image]](http://inlinethumb33.webshots.com/45920/2974326090104986527S600x600Q85.jpg)
[Re: Montero84]
#890238
11/08/10 03:20 AM
No mods, all stock. When I put the 33" muds on, I trimmed the front bumper ends just a little, like this: Second, I cut out the leading edge of the inner fender wells, visible slightly in these frames: Same tires, level ground with bumper: Same tires/rims, different Montero with no mods: <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Bhealy]
#890239
11/08/10 04:21 PM
Falken Wildpeaks are a cheap AT. I'm considering a set for all-time use instead of switching back and forth. I'm looking at 33's. I think they only make them in 12.5" wide though. I think 30x10.5 would be better for road/highway with a 4cyl.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift). 5500lb winch, Starion alternator, grp31 marine bat' OBA (stock AC compressor) 33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
