Page 2 of 3 1 2 3
Re: Opinions on Raider/montero tire size [Re: Bhealy] #890230 06/13/08 08:01 PM
Les Schwab is so overpriced. <img src="/forums/images/graemlins/evil.gif" alt="" />
I bought and traded parts for the alloys I have (all 8) and bought some cheapy tires....all for around $500. Check out Craigslist, Pirate, and 4x4Wire classifieds, you're likely to find some good used tires for cheap. I ran 25k miles on a set of Pirate sourced tires for $80!
Even WalMart sells BFG all terrains for $125/each or so...
Re: Opinions on Raider/montero tire size [Re: rxinhed] #890231 06/13/08 08:05 PM
Bhealy Offline OP
Les Schwab's AT's are 95 a piece and the wheels are 52....
87' Raider: off road package, rebuilt engine with (new) stock tires and alloy wheels but otherwise original.
Re: Opinions on Raider/montero tire size [Re: Bhealy] #890232 06/13/08 08:34 PM
jerzboy Offline
i would go 33"s. i live near the canadian rockies and have a 2.6 in my unit. have no issues with the 33"s for driveability and they look bad <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
'09 Acura TSX Tech Package
'05 Blazer (Company hauler)
Retired '88 Bada$$ edition Raider (now owned by shadowgear)
Re: Opinions on Raider/montero tire size [Re: Bhealy] #890233 06/13/08 09:43 PM
Something like this:
Pirate ad #1
Pirate ad #2
4x4wire ad (here)
<img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Opinions on Raider/montero tire size [Re: FrankR] #890234 06/14/08 12:56 AM
RichSmith Offline
Believe me, there is NO SUBSTITUTE FOR STUDDED TIRES ON ICE!! I live near Snoqualmie Pass (55 miles e/o Seattle). As you know we get a lot of deep snow, snowplow after-freeze, freeze thaw, crusty ice, ice storms etc., etc. During winter the conditions are always changing from hour to hour. Studless tires are a joke. So you'll need a second set of STUDDED tires & wheels for winter.
Your next consideration is whether or not you also need CHAINS. Chains require a lot of wheel-well clearance, so you couldn't use a big diameter tire if you do. You also need to decide how often you will be driving in DEEP snow. Narrow tires work better than wide in deep snow.
All things considered, I recommend a 235x75xR15 LT. Not too tall or wide and they still leave enough room for chains. Tread pattern is a personnal choice, but STUDDED TIRES ARE IMPORTANT.
Rich Smith
Re: Opinions on Raider/montero tire size [Re: RichSmith] #890235 06/14/08 01:37 AM
Under certain conditions maybe. Including those your way? There is no one in the Iceland contingency with narrow tires. Quite the opposite. They go to great lenghts to modify the sheet metal to fit the likes of 38X15.5 or such.
Re: Opinions on Raider/montero tire size [Re: rxinhed] #890236 11/07/10 09:51 PM
Montero84 Offline
rxinhead.. did you need to lift your Raider in order to fit the 33"?
Re: Opinions on Raider/montero tire size [Re: Montero84] #890237 11/07/10 11:40 PM
2" BL, torqued torsion bars, & gen ii coil springs on my 89 v6. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Opinions on Raider/montero tire size [Re: Montero84] #890238 11/08/10 03:20 AM
No mods, all stock.
When I put the 33" muds on, I trimmed the front bumper ends just a little, like this:
Second, I cut out the leading edge of the inner fender wells, visible slightly in these frames:
Same tires, level ground with bumper:
Same tires/rims, different Montero with no mods:
Re: Opinions on Raider/montero tire size [Re: Bhealy] #890239 11/08/10 04:21 PM
djacidjac Offline
Falken Wildpeaks are a cheap AT. I'm considering a set for all-time use instead of switching back and forth. I'm looking at 33's. I think they only make them in 12.5" wide though. I think 30x10.5 would be better for road/highway with a 4cyl.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6428 MB (Peak: 0.7693 MB) Data Comp: Off Server Time: 2026-07-15 02:13:13 UTC
