carpet soaked #890248 06/12/08 12:54 AM
supersport35 Offline OP
hello all...I was just wondering if anyone else has this problem...the driver side carpet is soaked and I dont know where the water is coming from....someone said that the sun roof vents are plugged,and are draining down there. but I blew them out and poured water down them and they drained fine.thanks
Re: carpet soaked [Re: supersport35] #890249 06/12/08 06:54 AM
kewlynx Offline
You also have drain plugs in the hood vents. Also check the grommet in the firewall on that side to make sure it's not rotted out.
If it's a stick, better make sure your clutch master cylinder isn't the culprit; it'll leak there too.
**ubi apis- ibi salus**
Re: carpet soaked [Re: supersport35] #890250 06/13/08 03:30 AM
thanks I'll check those points
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5931 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-06-23 00:50:37 UTC
