ATF as alternate fuel
#890285
06/12/08 05:16 AM
I am seriously considering running straight, used ATF in my 4d55. Anybody have any experiences running ATF? I was going to filter it through a 3 step process down to 1 micron. Could it hurt anything, injection pump, or injectors, mabey wear out any seals or o-rings? Any recomended upgrades (injectors, fuel lines) before I try this? Thanks.
84' twin turbo diesel PowerRam 50, Rockwells, 4 linked, 47" LTB's, dual cases
Re: ATF as alternate fuel
[Re: rockrenegade]
#890286
06/12/08 10:34 AM
ive read of using SVO as well as BIO-DIESEL I WAS ALWAYS TAUGHT THAT YOU COULD USE ATF AS A EXTRA LUBE BUT NOT AS A FUEL THAT WOULD BE AWESOME IF YOU COULD I USE A QUART OF ATF TO 20 GAL DIESEL SO THAT I HAVE PLENTY OF LUBE WHEN RUNNING NITROUS OR PROPANE I KNOW WHEN YOU RUN NITROUS AND PROPANE THE EXTRA FUEL THINS OUT THE LUBING ABLITIES OF DIESEL SO IM NOT SURE BUT I DONT THINK IT WILL WORK WHAT TYPE OF BTU RATTING DOES ATF HAVE COMPARED TO DIESEL AND AT WHAT TEMP DOES IT IGNITE YOU MAY HAVE A HARD TIME STARTING THE TRUCK WITH SVO YOU NEED TO WARM THE ENGINE UP ON DIESEL FIRST THEN SWITCH OVER SO YOU MAY NEED TO LOOK INTO SOMETHING LIKE THAT GOOD THOUGHT LET ME KNOW IF YOU TRY IT I HAVE A UNLIMITED SUPPLY OF THAT CRAP
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED 1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW CURRENTLY LOCATED IN JAPAN
[Re: rockrenegade]
#890287
06/12/08 04:19 PM
Why are you seriously considering running straight, used ATF in your 4d55? I can't imagine any benefit unless you are getting it for free.
I have read of guys burning ATF in a diesel generator, but why you'd want to do this in your vehicle is beyond me. I don't imagine it would be good for anything.
[Re: drtydzl]
#890288
06/12/08 10:15 PM
ive read of using SVO as well as BIO-DIESEL I WAS ALWAYS TAUGHT THAT YOU COULD USE ATF AS A EXTRA LUBE BUT NOT AS A FUEL THAT WOULD BE AWESOME IF YOU COULD I USE A QUART OF ATF TO 20 GAL DIESEL SO THAT I HAVE PLENTY OF LUBE WHEN RUNNING NITROUS OR PROPANE I KNOW WHEN YOU RUN NITROUS AND PROPANE THE EXTRA FUEL THINS OUT THE LUBING ABLITIES OF DIESEL SO IM NOT SURE BUT I DONT THINK IT WILL WORK WHAT TYPE OF BTU RATTING DOES ATF HAVE COMPARED TO DIESEL AND AT WHAT TEMP DOES IT IGNITE YOU MAY HAVE A HARD TIME STARTING THE TRUCK WITH SVO YOU NEED TO WARM THE ENGINE UP ON DIESEL FIRST THEN SWITCH OVER SO YOU MAY NEED TO LOOK INTO SOMETHING LIKE THAT GOOD THOUGHT LET ME KNOW IF YOU TRY IT I HAVE A UNLIMITED SUPPLY OF THAT CRAP Ive been reading about guys running ATF for awhile. The people doing it have nothing to complain about other than poor mileage, frequint filter changes, and problems in cold weather. A lot of people don't think it's possible or it will wreck the engine. The guys that I had read about are from Montana and are mechanics at dealerships (Dodge and Ford). They are running ATF in late model, computer controled deisels. They ran straight, filtered, used ATF with a quart of 2sroke outboard oil. One guy claims to have put 80,000 miles on his rig running it this way. With my 4d55 being a fully mechanical diesel, the only thing Im worried about is wearing out injectors, or any rubber components, like seals and gaskets in the fuel system. Wor out seals in my hydrolic pump running ATF in my hyro steering. What else should I be worried about? I think this truck will be a pefect test vehicle for this. Its a stricktly off-road vehicle that might see 100 miles a year. I was interested in running SVO also. But there is alot to it. Heated tank, heated fuel filter, new injectors with different spray pattern and angle, multiple tanks. ATF could be cool.
[Re: rockrenegade]
#890289
06/13/08 11:12 AM
try it and let us know i get it for free so im in if it works out for you id give it a go to then let us know
[Re: rockrenegade]
#890290
06/13/08 04:43 PM
I've read that you can use ATF to help lubricity in diesel fuel, so maybe it won't hurt.
But how much energy does it have per volume compared to diesel? Also, there are many kinds of ATF, probably not all of them are suitable to be used as fuel, some may degrade the seals and hoses, others may not.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
[Re: Glock24]
#890291
06/13/08 06:03 PM
on our ford tech forums there are over 700 posts about using ATF as a fuel in the powerstroke. many ppl are doing this and a few are using it in older benz and VW diesels too.
seems the biggest issues are hard starts in cold temps and slight smoking when cold.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
