Making some room under the hood. #890300 06/12/08 09:26 AM
Nick Muzzio Offline OP
Wanted to pull out my cruise control and AC system.
for the cruise system:
-How hard is it to pull out the cable
-if I just cap the vacuum line will that adversely affect anything.
for AC:
-If I wanted to completely remove the compressor, what would you recommend to do with the serp belt and pulley? It seems like it would be a long stretch for the belt go from the Alternator to the power steering pump. Maybe I could put something else in that spot like another alternator??
-How hard is it to pull out the rest of the tubing and whatever is behind the firewall?
Thanks in advance!
91 Trooper LS, 5 Speed Manual
3.4L Engine w/4.3L Throttle Body
Snorkel, 31" Pro Comp MT Tires, 2"lift,
ProComp ES9000 shocks and steering stabilizer
http://members.cardomain.com/sun_thief
Re: Making some room under the hood. [Re: Nick Muzzio] #890301 06/15/08 08:06 PM
Just wanted to give an update on this.
-The cruise wasn't so bad. The cable goes all the way to your gas pedal, it pops right off the pedal clip and wasn't an issue at all.
-now the ac wasn't too bad either. I wasn't able to pull the condenser or whatever is behind the firewall (have no idea how to get back there, probably have to pull apart the dash and go that way.
I am really looking to pull the compressor too, has anyone had any luck with that? Not sure what to do with the belt. I would assume I should keep the pulley there but it seems like I should put more tension on the belt by lowering the pulley a bit. Again not really sure how to achieve this. Any suggestions would be great. Thanks
Re: Making some room under the hood. [Re: Nick Muzzio] #890302 06/15/08 11:14 PM
maxwell417 Offline
Life here without a/c is unbearable <img src="/forums/images/graemlins/evil.gif" alt="" />.
But, why not keep the compressor and use it for onboard air?
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Making some room under the hood. [Re: maxwell417] #890303 06/16/08 03:28 AM
It's actually has a leak anyway. So I tried putting my belt on without the ac compressor and with the pulley it looks like it might work even though its a long run from the alternator to the power steering. So I think I'm just going to try without it! Wish me luck!
Re: Making some room under the hood. [Re: Nick Muzzio] #890304 06/16/08 03:57 AM
Jim_Paget Offline
There is a different part number for the belt on engines without the A/C. You should be able to just use that belt.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Making some room under the hood. [Re: Jim_Paget] #890305 06/16/08 05:47 AM
Yeah I wish, but I've already taken off my little air pump for the exhaust. I was told it would jam up when I took it underwater. It's ok I just get to take a couple trips to autozone.
Just out of curiosity, what does the non ac trooper do with it's belt. Anyone have a picture?
Re: Making some room under the hood. [Re: Nick Muzzio] #890306 06/17/08 07:59 AM
Found a belt that works! Here is the part number if anyone is interested:
first gen chevy v6 2.8L or 3.4L engines, bypassing ac compressor and smog pump
798K6
seems to fit great!
Re: Making some room under the hood. [Re: Nick Muzzio] #890307 06/25/08 07:20 PM
Just wanted to update everyone. The old belt was a little too loose. I went back and got a Duralast 790K6 and it fits much better.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6249 MB (Peak: 0.7248 MB) Data Comp: Off Server Time: 2026-06-09 21:48:53 UTC
