First oil change #890699 06/15/08 12:45 AM
G
george3 Offline OP
They bought back my 2000 Taco. It was like winning the lottery, so I put the $ down on a new one. ItÆs my first new truck. I have always change oil and filter at 3000 miles. I figure the manufacturers have extended oil change intervals so the vehicle has to be replaced more often or so they can advertise low maintenance costs. I am not waiting even to 3000 miles for my first oil change. When would you guys recommend the first oil change?
Re: First oil change [Re: george3] #890700 06/15/08 08:11 AM
humanoid Offline
Whatever the manual says to do. Oil changes at 3K miles using dino oil is a thing of the past and is a ploy by the oil companies to help them make more money. I also believe it's just a waste of resources as well. Oil manufacturing and oil additives are far more superior than when compared to your dad's or grandfather's days when they were driving. Tolerances in engine building are much better too. With newer cars and trucks, I've seen change intervals at 7.5K with dino oil, specified in the owner's manuals. They have extended intervals because vehicles are made better these days, not because the car companies want their cars to breakdown faster as you put it. What car company wants to have that reputation? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: First oil change [Re: humanoid] #890701 06/16/08 07:55 PM
BIGBURLYNAKEDMAN Offline
I agree with humanoid. It's just the fact that the autos really are that much better and cleaner-running these days.
However, I'd recommend forking out the extra dough for synthetic oil, and sticking with it for the life of the truck.
The lubricating agents and its resistance to breakdown are far superior to conventional (or dino) oil, and the change intervals are usually between 10,000 to 15,000 miles! Plus, you can use a thinner oil like 5W-30 (which has been said to increase mileage) and still have the protection of a higher-weight dino oil. I've been using full synthetic in my truck since I got it (every 6000-10,000 miles), and I'm at almost 190,000 miles on the truck and it still runs strong. <img src="/forums/images/graemlins/cheers.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: First oil change [Re: BIGBURLYNAKEDMAN] #890702 06/17/08 01:13 AM
john_luttrell Offline
I change the oil in my 2001 Tacoma around 6-7k miles and the oil doesn't even look dirty yet. The oil in my old jeep looks old after a couple hundred miles.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: First oil change [Re: BIGBURLYNAKEDMAN] #890703 06/17/08 01:20 PM
ACES_HI Offline
Toyota recommends 5W-30 dino oil. It can be run safely and is not too thin. Yes it offers less resistance than 10W-30 and maybe better mileage. Synthetic is fine also but everything that I've read says that change intervals are increased maybe a couple thousand miles but certainly not 10k - 15k. <img src="/forums/images/graemlins/zombie.gif" alt="" /> Remember the oil may last longer but the filter doesnt. Conversely youre paying extra money for the couple extra thousand miles and I like to lube the shafts every 5k so while under there might as well change the oil.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: First oil change [Re: ACES_HI] #890704 06/17/08 06:03 PM
Yea you're right about the change intervals to some extent. Looking them up now, most synthetics are only about 7500 miles, so I partially take back that earlier statement. <img src="/forums/images/graemlins/baby.gif" alt="" />
But, many synthetic manufacturers are coming out with "extended performance"-type synthetics that do have those longer change intervals, including Amsoil and Mobil 1. I could've sworn Amsoil used to make some crazy 10 or 15k oil (I don't know if they still do), but it was super expensive! But if not, then I was dead wrong.
My girlfiend's Acura calls for something like 7500 miles between changes, but I don't know if they're using synthetic from the factory or not.
OEM recommends the 5W-30 and it does get better mileage (supposedly), but my biggest thing is that I wouldn't put all my faith in super-thin dino oil in a 115-degree desert environment! Especially if -- like me -- you tend to run a little over 3000 miles between changes.
In my own humble opinion, the synthetic will be far superior to dino in the long run, whether it's changed at 3000 or 7500 miles. Just my opinion though <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: First oil change [Re: george3] #890705 06/18/08 06:34 AM
humanoid Offline
Found a good article about oil change intervals:
http://tinyurl.com/3uy37x
Re: First oil change [Re: george3] #890706 06/18/08 07:35 AM
Stock02 Offline
Everything oil....Bobistheoilguy.com <img src="/forums/images/graemlins/kewl.gif" alt="" />
02 Tacoma Xcb 4x4, runnin 32"s, 2.5" Daystar spacers, 1.5" Downey HD shackles, AOR sliders, SkidRow Tcase skid, 20# CO2 setup
Re: First oil change [Re: george3] #890707 06/18/08 08:17 AM
kewlynx Offline
Back to the original question-- just like a breakin of a rebuild, change your oil after the first 500 miles and put whatever you're going to run in it for the rest of its life.
That includes the filter. <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
Re: First oil change [Re: george3] #890708 06/18/08 05:40 PM
ACES_HI Offline
If you're in that harsh of an enviroment then I would run synthetic and change every 5K and filter just for peace of mind. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6365 MB (Peak: 0.7468 MB) Data Comp: Off Server Time: 2026-06-07 04:20:00 UTC
