Solid front axle king pins etc. #890902 06/16/08 07:54 PM
P
PETE_YK Offline OP
Hey guys/gals, im in the middle of cleaning up a '82-ish solid front axle in preperation for a SAS. The axle i got here is missing both king pins and their bearings on one side. None of the parts stores where i live could track down any of these parts, as in their suppliers dont even make em <img src="/forums/images/graemlins/angry.gif" alt="" /> Are these OEM parts only? Does anybody know where else i can find these important parts? Thanks.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Solid front axle king pins etc. [Re: PETE_YK] #890903 06/16/08 08:54 PM
fourwd1 Offline
Yeah, they'd be dealer only, if they can still get them.
Try the 4sale/wanted forums of BBS's like this, or a local club BBS.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Solid front axle king pins etc. [Re: fourwd1] #890904 06/16/08 08:56 PM
bkg Offline
Bearings:
www.marlincrawler.com
www.allprooffroad.com
by king-pin, I'm assuming you mean the bottom caps? If so, they are pretty easy to come by. I'm sure I have 1/2 dozen somewhere. If you mean the top caps with the steering arms, who cares? You'll be replacing them w/ hi-steer anyway. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Brian K. Gallus
Re: Solid front axle king pins etc. [Re: bkg] #890905 06/17/08 12:02 AM
P
PETE_YK Offline OP
Thanks bkg... Yup, my mistake, i meant the "cap" on the bottom. However i just found one and was lucky enough to score it off a buddy. Heheh yeah, looked at the front axle break-down and the SAS kit and they do include the new steering arms. Am i also correct in assuming that most knuckle rebuild kits include those 2 little tapered bearings on the top and bottom of the knuckle?
Re: Solid front axle king pins etc. [Re: PETE_YK] #890906 06/17/08 12:39 AM
4Crawler Offline
Many of the rebuild kits include the knuckle bearings, just be sure and order a kit that does. For example, from Toyota, the basic rebuild kit does not include knuckle or wheel bearings, they are separate items:
- http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml#Cost
Re: Solid front axle king pins etc. [Re: 4Crawler] #890907 06/17/08 03:10 AM
Adam F Offline
Out of curiosity...would it be possible, in a bind lets say, to use a stock steering arm, bolt it in place of the lower bearing cap, and cut the steering arm portion off? Are the bolt holes the same? I'm pretty sure the bearings and races are.
97 4R, stock, daily driver
Re: Solid front axle king pins etc. [Re: Adam F] #890908 06/17/08 06:31 AM
OOP'S Offline
Bearings are the same and yes you could but do not forget the cone washers.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6205 MB (Peak: 0.7111 MB) Data Comp: Off Server Time: 2026-07-14 08:17:35 UTC
