The part number thread (1996 and newer trucks) #891130 06/17/08 09:06 PM
Adam F Offline OP
This thread is for any maintenence parts, aftermarket or OEM, for any 1996 or newer Toyota SUV or pickup. Please post your part number and I will add it to this thread.
1998 4Runner
Static Antenna Assy.: 86300-35090
ASCO/Aisin Seiki Clutch Master Cylinder: 31410-35310 (I3000-55036) ( www.thepartsbin.com )
ASCO/Aisin Seiki Clutch Slave Cylinder: 31470-35120 (I3010-54125) ( www.thepartsbin.com )
97 6 cylinder automatic 4-runner, radiator cap, Stant # 10241.
'99 4Runner (4WD, V6, auto) coil springs:
Front right: 48131-35400
Front left: 48131-35350
Rear (both): 48231-35210
Power steering boot part # 45535-35030
Lug nuts Alloy wheels # 90942-01095
wheel studs back(longer) # 90942-02052
wheel studs front # 90942-02049
4Runner upper spring supports:
48609-35030
3RD GEN Exhaust sensors for California emissions 4runners (a two catalytic converter system):
Front Air Fuel Ratio Sensor: 89467-35011
Rear Oxygen Sensor: 89465-49105
For 3RD gen 4runners with the "heavy duty" brakes that came stock on 4WD models with 16" tires many people like the Performance Friction brake pads & Brembo rotors. Here are the part numbers:
Performance Friction pads: Part# 4364
Brembo rotors: Part# 25488
The pads can be bought at AutoZone . The rotors can be bought at Tirerack.com or importrp.com
For 3rd generation 4runners polyurethane bushing replacements for the steering rack.
energy suspensions set part #: 8-10101
Installation writeup here :
or here
The writeup if for a 1996 tacoma. However, the steering rack looks identical and the installation identical to the writeup.
'96 4Runner
Front Axle CV Boot Kit 104438-35060
Approx Cost $25-$35
3rd Gen 4Runner fuel filter: 23300-62030
Here's a good write-up I used to change mine --> link
'98 4-Runner LTD 4WD 16" wheels, with ABS:
rear axle shaft: 4231135280 ?
rear axle bearing: 903634002077 (but the price and quality was much better at my local bearing supply place)
rear axle shaft seal, inner: 9031050001
rear axle shaft seal, outer: 9031348001
rear axle bearing retainer: 4242135030
97 4R, stock, daily driver
Re: The part number thread (1996 and newer trucks) [Re: Adam F] #891131 08/24/08 04:55 PM
skered53 Offline
Re: The part number thread (1996 and newer trucks) [Re: Adam F] #891132 08/28/08 03:11 AM
kewlynx Offline
FYI, I've got stuff posted over in the Taco section, given the 2.7's and 3.4's are dropped into them also. Yep, you have another place to look. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
**ubi apis- ibi salus**
Re: The part number thread (1996 and newer trucks) [Re: kewlynx] #891133 08/28/08 04:11 AM
Adam F Offline OP
Thanks! I'll steal some numbers from you.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6033 MB (Peak: 0.6607 MB) Data Comp: Off Server Time: 2026-06-21 20:21:54 UTC
