Changing Antenna on Gen 1: How big a PITA? #891242 06/18/08 04:49 PM
gtrotta Offline OP
Just curious if this is documented anywhere...my cable snapped up in the fender well somewhere.
I did a search and didn't seen anything. Of course, if anyone has a spare antenna to ship, I'd be grateful.
1987-2000: '87 black Raider stock 4-cyl/5-speed.
2000-2006: '89 black Raider stock 6-cyl/auto
2007-?: 89 black Raider, 6-cyl/auto w/(at last!), bouncy seat, power windows and cruise.
Re: Changing Antenna on Gen 1: How big a PITA? [Re: gtrotta] #891243 06/18/08 05:18 PM
IIRC you just remove the fender/tire well and you can access it, but I'll let someone w/ access to a manual or who's done it before elaborate on if I'm right or wrong. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Changing Antenna on Gen 1: How big a PITA? [Re: gtrotta] #891244 06/18/08 06:31 PM
It's easiest if you pull the fender. Unless you have very skinny arms, you'll have difficulty with the wire routing and getting the Phillips screw out of the body that hold the antenna in.
Re: Changing Antenna on Gen 1: How big a PITA? [Re: off-roader] #891245 06/18/08 06:35 PM
Yeah, just checked the FSM. After you unbolt the housing you'll need to remove the fender not the wheel well. Sorry for any confusion. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Changing Antenna on Gen 1: How big a PITA? [Re: off-roader] #891246 06/18/08 07:03 PM
hazy_daze Offline
I jacked it up, pulled the tire and fender liner to do mine. Thought it was going to be more difficult. Fishing the wire, now that's another story... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Changing Antenna on Gen 1: How big a PITA? [Re: off-roader] #891247 06/19/08 01:27 AM
Grasscat Offline
I never removed the fender to change mine. Just remove the plastic fender liner and it's there to work on. The screw was no problem. The last time I did it, I left the console in place. You can engage the cable with a little patience, well maybe a lot of patience. <img src="/forums/images/graemlins/lol.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Changing Antenna on Gen 1: How big a PITA? [Re: Grasscat] #891248 06/19/08 03:19 AM
52degrees Offline
leave the old wire in place, then tape the two together. Plan on using a lot of tape, far up both wires. Then you can use the onld wire to pull/guide the new one through the firewall.
Montero's aren't bad. Try a Silverado. Might as well be a silverback until you know the trick.
KG6VNX
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6165 MB (Peak: 0.6955 MB) Data Comp: Off Server Time: 2026-05-29 18:24:27 UTC
