Need closeup picture of a timing tab on a v6 first gen trooper #891359 06/19/08 04:06 AM
Nick Muzzio Offline OP
I've been driving a long time with my trooper timed by ear (don't think I'm good at it either). Anyway I wanted to try and make some marking to try and recreate the timing tab. If anyone has or would take a picture of the tab closeup that would be freaking awesome! If you could try and get the bolt holes in the picture too that would help. Thanks
91 Trooper LS, 5 Speed Manual
3.4L Engine w/4.3L Throttle Body
Snorkel, 31" Pro Comp MT Tires, 2"lift,
ProComp ES9000 shocks and steering stabilizer
http://members.cardomain.com/sun_thief
Re: Need closeup picture of a timing tab on a v6 first gen trooper [Re: Nick Muzzio] #891360 06/19/08 05:01 AM
mlclark Offline
Isuzu Moderator
It is a 60* GM engine. I would strongly bet there is an aftermarket part from either the V6 or 90* V8 world that would be a direct replacement.
IIRC, it is only a pointer and the markings are on the harmonic balancer. Set the engine to TDC on #1 and make something that points to 0*.
Good Luck,
Michael
Re: Need closeup picture of a timing tab on a v6 first gen trooper [Re: mlclark] #891361 06/20/08 05:22 AM
Ed Mc Offline
The degree marks are on the part which is bolted to the timing cover.
There's probably a lot of 2.8 S-10's in your local wrecking yard, and any TBI model '87 and newer would have the same timing cover with timing scale attached.
HTH.........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Need closeup picture of a timing tab on a v6 first gen trooper [Re: Ed Mc] #891362 06/20/08 06:34 AM
Hey Ed long time! I actually have been checking out the local salvage yards and haven't had any luck. If I do find a compatible motor, the yards usually don't want to sell me the tab, they want to keep it with motor. Thats why I was just going to try and wing it. At least I'll know I'm in the ballpark of in time. I also looked on ebay for some after market ones and the only engine in the world seems to be a 350.... I swear there is soo much more stuff for that damn engine! Oh well, I think I will be able to mark TDC, but I really just need to know about how fare over from TDC I need to go, it should be 6* advanced correct? If I can't get a picture an estimate on length from TDC will do. Thanks guys!
Re: Need closeup picture of a timing tab on a v6 first gen trooper [Re: Nick Muzzio] #891363 07/05/08 07:06 AM
Ed Mc Offline
Nick, if you're still looking for a timing cover, there's an '87 S-10 2.8 timing cover on eBay right now.
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320270818603
'90 Troop 3.4 LS
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6043 MB (Peak: 0.6694 MB) Data Comp: Off Server Time: 2026-06-13 10:52:44 UTC
