96 Montero LS front axle parts. Soloniod Valve? #891527 06/20/08 05:02 AM
chris40 Offline OP
Does anyone know ballpark what's the cost of the solenoid valves that engages the the front hubs on a 96 LS? They sit on the inside right fender. I tried cleaning out both and also replaced all the lines I still have the front hub lites flashing and sometimes when I come to a stop I feel the truck shudder as if it just either engaged or disengaged
EDIT... I cleaned up your title, spelling, and Grammar.. Hopefully someone who has some good info for you will drop by soon. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 96 Montero LS front axle parts. Soloniod Valve? [Re: chris40] #891528 06/20/08 03:29 PM
NathanC Offline
What makes you think it is the valves? Did you test them?
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: 96 Montero LS front axle parts. Soloniod Valve? [Re: NathanC] #891529 06/20/08 04:43 PM
Alex Kogan Offline
do you have tires of the same size? Those things rarely fail.
08 PowerWagon (stock!)
Re: 96 Montero LS front axle parts. Soloniod Valve? [Re: Alex Kogan] #891530 06/22/08 06:25 AM
V
vr4 Offline
i had the same issue on my SR once in the last 2 weeks. hasnt happened again. my mazda also has the same issue where it tries to engage the front diff (has the same basic design as the montero) while driving. never did figure out what was causing it so i just leave it locked now and leave the t-case in 2wd.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-06-10 01:48:27 UTC
