Fluid Change Interval
#891721
06/21/08 10:14 AM
Toyota recommends changing out the transfer case oil every 30K but not the tranny or diff oil? Whats a realistic change interval for all of the above? 30K seems way premature. <img src="/forums/images/graemlins/confused.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver) '90 x-cab 22RE stock '82 Hilux 6" lift (ACES HI) '82 2-Hiluxs' Rally Edition (parts) '81 Hilux 3" lift (parts/restore)
Re: Fluid Change Interval
[Re: ACES_HI]
#891722
06/23/08 04:02 PM
All depends on what your doing. if your out playin gin the mud and crap then i would be doing the diffs at least once a year if not more. 30k seems a little early for t case i would do trans and t case every 60 at least. I just changed my trany and diff after about 4 years and it was as clean as teh day i put it in. Imm in the process of changing everything over to synthetic in the trany, t case and diffs. Did the trany and t case and can notice the diff in how much better it shifts and getting a bit better gas millage
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5862 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-07-13 11:03:27 UTCValid HTML 5 and Valid CSS
