22r wont fire please help
#891810
06/22/08 02:23 AM
Re: 22r wont fire please help
[Re: 87YODA]
#891811
06/24/08 05:23 AM
Check the grounds from the battery to the body, and the body to the body of the coil/ic igniter. I had a similar problem. I solved it by running an additional ground cable from the point on the body where the battery ground goes to the starter mount bolts. This gives the starter a much better ground than going through the cheesy strap ground that has gotten corroded and nasty. Mine would crank all day but no sparky. It would push start though.
[Re: xrtim]
#891812
06/25/08 01:32 AM
I checked my grounds, they seem fine. You say a ground going to the coil which wire is that? I only see the 2 little wires going into the coil from the plug. I cleaned the battery to body ground and tried to fire it up and it fired and almost started but the damn battery was too low. I charged the battery and tried it again but it did the same thing, I tried to jump start it and then it wouldnt fire at all.... <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: 87YODA]
#891813
06/26/08 04:37 AM
Mine had a jumper wire running from the body of the coil/igniter to one of the bolts on fender well. When I rebuilt the IC igniter, I ran a new/bigger jumper just in case. Could also be your ignition switch. You can check that with a meter and schematic.
[Re: xrtim]
#891814
06/27/08 01:19 AM
this is so frustrating still cant figure it out.
[Re: 87YODA]
#891815
06/27/08 11:22 PM
ok today I finally got it to fire and start and run for about 8 seconds then it died. It was cutting in and out. Now I cant get it started it just turns over but wont fire I think. I cant figure out what the deal is.
[Re: 87YODA]
#891816
06/28/08 02:08 AM
Does the breather assembly have to be on the truck while you try to start it to make it run properly? I have had it off this whole time if that makes any difference.
[Re: 87YODA]
#891817
06/28/08 05:37 AM
Is it making spark the whole time you are cranking? sounds like it could be the ic igniter. Assuming all your connections are tight. The breather situation should not affect anything electrically and the engine should at least try to run even if it's messed up. The IC igniter is tough to diagnose. Mine simply failed and the engine had no spark no matter what. I've heard that some come and go for a bit before checking out forever. Lemme know if you need an igniter, I've got the plans to make one yourself for cheap and it works, I've been using one for almost 2 years now. xrtim@sbcglobal.net
[Re: 87YODA]
#891818
06/29/08 06:13 AM
Well I tried it again and this time the truck started up and ran first try, but died after about 15 seconds, it was also cutting out a bit. I am thinking more of a fuel problem now.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6247 MB (Peak: 0.7282 MB) Data Comp: Off Server Time: 2026-05-28 01:02:50 UTCValid HTML 5 and Valid CSS
