broken 4wd hub mounting bolts #891849 06/22/08 05:40 AM
rolled Offline OP
'94 hilux, shortbox.
on the wheel hub, is there any (easy) way to replace the mounting studs (at least the broken ones) for the 4wd hub???
it all started with a broken wheel stud. and i figured since i had to take everything apart that i would repack the wheel bearings. things always take a little longer than i expect, it got late, i got lazy and was using the impact wrench to spin the 4wd hub nuts back on. spun one off with the impact. i thought i would just let it ride for now and repair it later. then i spun another one off by hand.
guess its time for a tork wrench.
any help would be great.
thanks!
rolled it on a snowbank. now i'm not afraid to scratch it. liberation.
Re: broken 4wd hub mounting bolts [Re: rolled] #891850 06/24/08 01:04 AM
Adam F Offline
2 ways to do it. If you have any threads left, clean them up, and grind the head of the stud flat so that you can get a nut back on. Then double nut the stud by threading one nut on, followed by another nut, tighten the top nut against the bottom nut. Now get a wrench and loosen the 2 nuts together, and the whole stud should come out.
If you dont have threads or that doesnt work, grab a good set of vice grips and twist the thing out of there. That is, unless you broke it off completely flush. Then you'll need to buy a set of bolt extractors.
97 4R, stock, daily driver
Re: broken 4wd hub mounting bolts [Re: Adam F] #891851 06/29/08 05:35 PM
rolled Offline OP
no threads left, tried the vice grips with no success. its difficult to do this work in a sandy driveway...
local machine shop was able to extract my broken studs for a few measley dollars.
thanks for the comment.
j.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5941 MB (Peak: 0.6478 MB) Data Comp: Off Server Time: 2026-11-18 03:28:21 UTC
