Proper Way To Start? #891926 06/22/08 09:46 PM
koolaid6666 Offline OP
I have a 01 Montero Diesel In Dominican Republic, What Is the proper way to start the engine if there is one? The truck Doesn't want to start In The Morning It's hard to start, when It gets going I have to wait about five minutes before moving It or If I try it sputters then shuts off and doesn't want to start back up.It runs normal all day long with no problems only in the morning the weather never goes below 60 degrees Fahrenheit. Is this just Normal with Diesel's? I just changed the filter also. This Is my First diesel.
2003 Montero Limited White
2001 Montero GLS Diesel
1990 Montero Black Off Road Package.
1990 Montero Parts Truck.
Re: Proper Way To Start? [Re: koolaid6666] #891927 06/22/08 11:18 PM
bae146 Offline
I would guess that you have a problem with your glow plug system. The newest Diesel Pajero we have in Canada is a 1993 so I cannot help you to much other than to check your glow plugs for 12 volts when you turn on the key. You can also check the busbar that connects the plugs together for corrosion. The last thing to do would be to remove all your glow plugs, inspect them and measure the resistance from the center connector to the case. there should be very little resistance. Can't remember off hand what the resistance should be but it should be less than one ohm.
Re: Proper Way To Start? [Re: bae146] #891928 06/23/08 01:46 AM
That I will do.Were Can I get Glow Plugs from Here In The US? Is there any web sites I can Order from? I'm going back Down At the end of August
Re: Proper Way To Start? [Re: koolaid6666] #891929 06/26/08 11:21 PM
RuffStuff Offline
I was reading on Pocuk.com that the symptoms you describe signal problems with the injection pump seals on the 2.8L. take a look on the Pocuk website and search "fuel pump". It will have lots of info there.
Re: Proper Way To Start? [Re: RuffStuff] #891930 06/27/08 01:48 AM
Bernoulli Offline
I second the "check Pocuck". There's lots of info there.
To me it sounds like glow plugs inop: - either bad glow plugs or no power to them.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Proper Way To Start? [Re: Bernoulli] #891931 06/27/08 10:30 AM
Great That's the kind of web site I was looking for. I have some reading to do. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6104 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-06-09 22:00:23 UTC
