Factory Infinity Stereo Security Code Issue in '98 Montero
#892195
06/23/08 06:20 PM
I did a couple of searches and could not find the answer to this.
I am the second owner of this truck, and I appear to have the premium Infinity sound system with the 10 disc CD changer in my '98 full size Montero. My factory radio lost power and is now asking for a 4 digit security code. There doesn't seem to be anyway to bypass this. Is there anything I can do to get this working? I don't have the extra cash to purchase and install an aftermarket system right now. Thanks for your input.
'98 Montero, 146K miles, needing Suspension and Tire Upgrades '03 Montero Limited, 121K miles stock, original owner '82 Toyota Supra, Spearco Turbo Kit and too many mods to list (in need of turbo rebuild)
Re: Factory Infinity Stereo Security Code Issue in '98 Montero
[Re: Chad_in_Colorado]
#892196
06/23/08 07:03 PM
if your dealer is willing to work with you or you know someone there they can get the code for you off their tech website.
im not sure if you need just the VIN or the VIN and the radio numbers. expect to have your registration too.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
#892197
06/23/08 07:13 PM
Some quotes from search: The Gen II's have a radio security feature built into them. When ever the power is disconected it is reset. I don't know how the code is determined, but I think it is generally written inside the manual. Otherwise you'll have to talk to the dealer. On my '00, the individual Radio Code was supplied on a separate little Credit Card-sized "document" within the Owner's Manual so that it could be kept somewhere separate from the Vehicle. The Dealer programmed in the Code before I picked up the Vehicle.
call the dealer. I was leaving for a trip and that happened. I calld the dealer after I was about 50 miles away. HE lookedup the code and talked me through it. Easy and fast. Then you mark the code in your manual and it never happens again.
With the radio serial number and his VIN he can call 1-888-MITSU2005 and they'll give him the radio code for free. You may try calling your local mitsu dealer and giving them your vin number. they maybe able to hook you up with your code for the radio.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#892198
06/23/08 10:26 PM
WOW! I need to learn how to use the search function better! My apologies, and thanks for the responses.
#892199
06/23/08 10:43 PM
No problemo. When searching for specific keywords, put a "+" sign at the start of each word, such as +security +code. Or you could enclose a search phrase within quotes, such as "security code". Of course, tailor your search to the forum(s) being searched, the username who posted what you might thinking of (if you know), the date range, and number of posts per result-page.
[Re: CapnCrunch]
#892200
06/24/08 02:59 AM
I called several dealers until one gave me the code using my vin and code on a sticker on the radio (have to remove it to get this)
1995 Montero SR 1999 Montero 1974 Ford Bronco
[Re: bOURGE]
#892201
06/24/08 03:45 AM
I called several dealers until one gave me the code using my vin and code on a sticker on the radio (have to remove it to get this) Of course you probably didn't realize it then but thats why you should call the toll free number instead. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
