'98 Full Size Montero Stock Wheel Size #892265 06/24/08 12:03 AM
Chad_in_Colorado Offline OP
Maybe I need to learn the search better, but I searched +Stock +Wheel +Size, or something like that and searched through 4 and a half years of posts and couldn't find this info. Tons of info on Gen I's and a little on Gen II's....nothing on Gen II.5's.
So, can anyone tell me the stock wheel WIDTH on the Gen II.5? Is there an easy way to check?
I was under the impression that I have 15x8's, but someone told me that they were pretty sure they are 15x7's. I don't have new wheels in the budget and I like the look of the stock wheels. So, that makes a big difference in what tire width I purchase. Any help is appreciated. Thanks.
'98 Montero, 146K miles, needing Suspension and Tire Upgrades
'03 Montero Limited, 121K miles stock, original owner
'82 Toyota Supra, Spearco Turbo Kit and too many mods to list (in need of turbo rebuild)
Re: '98 Full Size Montero Stock Wheel Size [Re: Chad_in_Colorado] #892266 06/24/08 12:29 AM
lordtrunks Offline
15X7
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: '98 Full Size Montero Stock Wheel Size [Re: lordtrunks] #892267 06/24/08 11:38 PM
That is a bummer, so I basically have to choose between 33x10.5's and 32x11.5 (which technically are too wide, but can work) 1 inch taller or 1 inch wider....in BFG's they both weigh the same. The 32's are $18 more per tire....hmmm
Knowing that I am putting a 2.75" suspension lift on the truck before the tires get fitted, and down the road, plan a 1-2" body lift, which would you choose and why?
Re: '98 Full Size Montero Stock Wheel Size [Re: Chad_in_Colorado] #892268 06/24/08 11:50 PM
lordtrunks Offline
go with the 33's your in a LWB your gonna want as much clearance under the belly as possible plus you'll shoot your self after you get those 32's and go wheeling.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6029 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-06-10 06:09:47 UTC
