towing a samurai #892392 06/24/08 10:29 AM
A
ALPMAN Offline OP
What is required to tow a samurai ? do I need to unhook drive lines or just take it out of gear I will be going about 300 miles in total and don't want to ruin anything thanx for the help
ALP
Re: towing a samurai [Re: ALPMAN] #892393 06/24/08 07:49 PM
TXrazor Offline
Got this off another forum. <img src="/forums/images/graemlins/patriot.gif" alt="" />
This is how you flat tow your Samurai:
Steering column unlocked: you can do this by turning the key to the on position then returning it to off and leaving it in the ignition, this way you don't have to disconnect your battery.
Unlock your Hubs
T-case in N, with the Tranny in 2nd gear, sounds weird but this keeps the intermediate shaft from spinning on a dry bearing, tranny in nuetral will work for short trips.
Better then leaving the t-case in neutral is just to remove the rear driveshaft, with teh hubs unlocked your front driveshaft isn't going to spin, this will save on bearing wear and you won't have to worry about the t-case popping out of gear and trying to make your engine explode. if its cold or you are just feeling lazy, you can only remove the 4 bolts at the axle flange and pull the driveshaft, apart, personally i don't like the looks of half a driveshaft just hanging out underneath, so i take the whole thing out.
Try and get your towbar as level as possible and try and get your mounts in line with the frame rails.
http://www.greatlakes4x4.com/archive/index.php/t-764.html
91 Montero SuperWagon LWB, Pro Comp Xterrains, Blk Steel RockCrawlers, Aisin Locking Hubs, Pro Comp 9" HID Lights, Projector H4 Headlights, ARB Bull Bar, K&N, Alpine, Optima and a Hella loud Hella Horn... More to come!!!
Re: towing a samurai [Re: TXrazor] #892394 06/25/08 05:03 AM
Billjohn Offline
Good response.
Here is another way to go. I run one of these on our 'Stalker' project vehicle. We towed it over 4K miles last year with no problems whatsoever.
Drive Shaft Disconnect
Bill
God Forgives, Rocks Don't...
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5933 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-05-30 01:21:38 UTC
