Couple 2.6l pickup/montero questions #892638 06/25/08 07:36 AM
Chris009 Offline OP
My 88 Mitsu 2.6 mighty max has been running a bit warm lately, so I wanted to go through the cooling system and give everything a checkup. Radiator is pretty dirty, so I pulled it and will get it cleaned out tomorrow. Since I have it apart....can anyone confirm or deny, is there supposed to be a spring in the lower radiator hose?
Also I have one more annoyance, I have no good means to tighten the alternator belt. Granted, there is a 'bracket' on top of the alternator, one end bolts to the A/C compressor bracket and the other end has a hole with a 90 degree bend, this is the end on the drivers side. It sure looks like it should have an adjuster bolt present, but right now all I have is a regular bolt going through the bracket and into the alterntor. Car was given to me this way, the problem is I have to pry on the alternator to try and get the alt/water pump belt tight, which I don't like doing. Anyone have a picture of this part of the engine with the adjuster for the belt visible? I'll probably have to get this stuff from the stealer...if I have a pic it may make things go a little easier.
Thanks,
Chris
Re: Couple 2.6l pickup/montero questions [Re: Chris009] #892639 06/25/08 08:53 AM
CapnCrunch Offline
Yes, the lower hose should have an internal coil to keep it from collapsing.
And yes, there is an adjuster bolt. Below is a blow-up of the area:
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5899 MB (Peak: 0.6388 MB) Data Comp: Off Server Time: 2026-06-07 03:17:17 UTC
