cool engine #892816 06/26/08 04:59 PM
tomzsix Offline OP
Are there any downsides to having the 2.6 engine operating cooler? I have installed, what I believe, an original 3- row radiator from a junked out 86. What a difference it made from the 2- row.
Tom Tucker
Re: cool engine [Re: tomzsix] #892817 06/26/08 05:21 PM
Bhealy Offline
From what a mechanic told me when I installed a 325i radiator into my 1971 BMW 2002; As long as it is running in the correct range you will be fine, and colder coolant temps usually translate into more power (density of air greater). My temp gauge sits right on top of the blue which is perfect. Hope this helps
87' Raider: off road package, rebuilt engine with (new) stock tires and alloy wheels but otherwise original.
Re: cool engine [Re: tomzsix] #892818 06/26/08 08:14 PM
G
generation_one Offline
as long as thermostat, waterpump, lines are good then it wont make any difference.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: cool engine [Re: generation_one] #892819 06/26/08 08:15 PM
G
and...fan, clutch, shroud
about 200k miles
Re: cool engine [Re: Bhealy] #892820 06/26/08 09:23 PM
tomzsix Offline OP
Also, the cooler the gasoline, the more efficient it is upon combustion. And I think the EGR will work better too, but I don't really know.
Tom Tucker
Re: cool engine [Re: generation_one] #892821 06/26/08 10:02 PM
V
vr4 Offline
agreed.
a larger radiator wont make it run cooler. it will however help with overheating.
your engine temp is regulated by the thermostat. it doesnt matter if you have a 10 row radiator in 30? temps, the engine will still operate at the thermostats opening temp (usually 192-195)
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: cool engine [Re: vr4] #892822 06/28/08 04:55 PM
tomzsix Offline OP
Also less exhaust smoke from the tailpipe. After a few days driving, I am using less fuel, and the dieseling of the engine has disappeared.
Tom Tucker
Re: cool engine [Re: tomzsix] #892823 06/28/08 07:58 PM
V
vr4 Offline
if changing a radiator did that you have other problems and the band aid temporarily covered them up.
91 MR2 turbo
Re: cool engine [Re: vr4] #892824 06/28/08 09:31 PM
tomzsix Offline OP
With cooler temps, and I mean much cooler,the fuel seems to be combusting efficiently. The heat frome the engine, I believe, affected the EGR valve and thermo valve to run hotter than normal, causing a rich fuel mixture. I dont know too much about how an engine works, but excess heat does play a part on rubber grommets, seals, and plungers.
Tom Tucker
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6267 MB (Peak: 0.7132 MB) Data Comp: Off Server Time: 2026-10-24 07:31:48 UTC
