87 22r won't start #892825 06/26/08 05:39 PM
thxgoon Offline OP
So I went out to start my truck last night and it ran for about 2 seconds before it died. Turns over fine but won't fire. No fuel in the float boal and whe I pulled the fuel lines off of the pump and carb there was nothing in them. Current suspect is the fuel filter but where the heck is it? Tried following the lines but I can't find it for the life of me. Anyone know where it is? Thanks.
Re: 87 22r won't start [Re: thxgoon] #892826 06/26/08 06:28 PM
toyomorph Offline
the earlier trucks fuel filter was on the passenger side firewall. Yours is probabaly under the vehicle near the fuel tank.
canyon country explorer
1993 4x PUP
Re: 87 22r won't start [Re: toyomorph] #892827 06/26/08 07:57 PM
thxgoon Offline OP
Thanks. Thats what the Haynes manual says too but its definitely not by the fuel tank unless it's on top of it. I'll take a closer look at the firewall. Saw somewhere that it is located under the intake manifold. Anyone know if this is true?
Re: 87 22r won't start [Re: thxgoon] #892828 06/26/08 08:13 PM
Staceman Offline
Under the intake on fuel injected 22R(e)
Pass. fenderwell on carbed models (unless previous owner moved it elsewhere?)
Re: 87 22r won't start [Re: Staceman] #892829 06/27/08 01:46 AM
toyomorph Offline
hey, I have an 87 CARB PU and the fuel filter isn't on the firewall passenger side. If I get a minute tomorrow I'll crawl under it and see if I can find the filter.
1993 4x PUP
Re: 87 22r won't start [Re: toyomorph] #892830 06/27/08 02:57 PM
Staceman Offline
Rear fender (wheel-well)
Between the gas tank and frame. Actually, if I remember right, the clip that holds the filter is attached to the inside of the frame back there.
Re: 87 22r won't start [Re: thxgoon] #892831 06/27/08 05:04 PM
Adam F Offline
Try running it on some starter fluid or pour a little straight gas in the carb and see if it runs. It is possible that you got some air in the lines, and running it this way can prime the system. This will also tell you if your getting spark.
Also make 100 percent sure your not just out of gas. Dont go by the gauge. Check the tank itself.
What about the fuel pump on the block? Did you pull the line going INTO the pump FROM the tank? Was that dry?
Get a 5 gallon can of gas and run a line from the can directly to the fuel pump, bypassing the filter. That should rule out problems with the filter.
Could also be leaks in the fuel lines coming from the tank, causing the pump to suck air.
Hopefully its something as simple as a clogged fuel filter. If it is clogged, you will want to figure out what clogged it, and where it came from, which means dropping the tank, and having it cleaned.
97 4R, stock, daily driver
Re: 87 22r won't start [Re: Adam F] #892832 06/27/08 05:16 PM
thxgoon Offline OP
Awesome thanks for all of the great advice and hints!
Well after leaving the fuel lines disconnected for a bit fuel began to stream out of the line, so I hooked it back up to the pump and still nothing. Must be the pump I decide so I go downtown and pick up a new one from napa, come back and try to start it just for the heck of it and it fires right up. Strangest thing. I'm thinking maybe it was a bad vapor lock situation? What do you think would have caused this to happen?
Re: 87 22r won't start [Re: thxgoon] #892833 06/27/08 10:39 PM
Bustedback Offline
It is 22 years old, it may have just worn out.
Re: 87 22r won't start [Re: Bustedback] #892834 06/27/08 10:45 PM
thxgoon Offline OP
A toyota wore out? Never!!
It's running fine now so I hardly think this is the case
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6292 MB (Peak: 0.7364 MB) Data Comp: Off Server Time: 2026-06-20 21:42:54 UTC
