T5 transmission question #892847 06/26/08 07:40 PM
dorkpunch Offline OP
I know, not Kia related... but you guys know everything, so...
I bought a '94 camaro last week. Its a peice of junk but it was cheap. It got the v6 and the 5 speed manual. Everything works great except the reverse. It will go in but as soon as you let the clutch out it pops out of reverse. If you hold it back in gear it will start to move but you really have to be pulling on it. SO. Need it rebuilt? Any linkage that can be adjusted? bent fork? Something I can do myself? Thanks all!
Re: T5 transmission question [Re: dorkpunch] #892848 06/27/08 12:16 AM
comp Offline
i have read ,,that a fluid change and pulling the shifter and replacing bushings has helped again i read this
Re: T5 transmission question [Re: comp] #892849 06/27/08 02:38 AM
jaboo5322 Offline
I had a
79 pinto that started same problem. Whithin a couple of weeks, it took two people to hold it in reverse. Probably bearings or bushings on the shaft that slide gear is on.
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5920 MB (Peak: 0.6450 MB) Data Comp: Off Server Time: 2026-11-02 14:20:54 UTC
