Timing Chain Covers #893123 06/27/08 11:45 PM
Bhealy Offline OP
Anyone know where I could locate a new Timing chain cover? In the middle of rebuilding the engine; threads were stripped in the holes closest to the water pump, so we drilled and tapped it to accept a bigger bolt. There isn't much area left to seal now, hoping it will work when I start er up. Down the road I may want to replace with a new timing chain cover; nada one place I've gone to has em. Ideas <img src="/forums/images/graemlins/confused.gif" alt="" />
87' Raider: off road package, rebuilt engine with (new) stock tires and alloy wheels but otherwise original.
Re: Timing Chain Covers [Re: Bhealy] #893124 06/28/08 12:10 AM
If nobody has one check msrecycling.com or car-part.com
Car-part is usually cheaper but you may be able to negotiate with msrecycling.com
Re: Timing Chain Covers [Re: Bhealy] #893125 06/28/08 01:22 AM
cjsmontero Offline
One word Russell
Re: Timing Chain Covers [Re: cjsmontero] #893126 06/28/08 01:31 AM
Alas, I have no timing covers. My travels through three yards today were for naught, I saw mostly 2L in the pickups and only 2 V6 Monty's.
Re: Timing Chain Covers [Re: rxinhed] #893127 06/28/08 02:36 AM
MainstreaM Offline
Turbo one work for you? I've got a couple.
Kane
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI.
87 Starion flatsider - under restoration
87 Conquest - Saved from the crusher
86 Conquest - Another crusher rescue
88 Conquest - Previous owner abandoned project
87 Raider - under construction
86 Conquest - DD
Re: Timing Chain Covers [Re: MainstreaM] #893128 06/28/08 02:44 AM
Bhealy Offline OP
no I just have the normal 4cyl 2.6 l carb. engine
Re: Timing Chain Covers [Re: Bhealy] #893129 06/28/08 04:16 AM
torquemonster Offline
the turbo one should work...isn't the only difference the tapped hole for the turbo oil-return line??? you can just shove a bolt plug in that hole and be good to go.
Re: Timing Chain Covers [Re: torquemonster] #893130 06/28/08 04:21 AM
99% sure that is a correct statement. Quite sure the cases are the same as a whole. And the pretty sure the oil return is the only difference on the turbos. IIRC, to do it in reverse, retro a turbo to a non-turbo, drilling and tapping the boss for the oil return was all that was needed on the cover.
Re: Timing Chain Covers [Re: MontyMcV] #893131 06/28/08 06:34 PM
Yes, just use a pipe plug (1/2" npt plug??) and save the turbo oil return nipple for later...
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6308 MB (Peak: 0.7343 MB) Data Comp: Off Server Time: 2026-11-16 01:27:14 UTC
