Rear Brake Drum Bolt #893196 06/28/08 01:22 PM
Richards19884x4 Offline OP
Can anyone tell me the size of the two bolt holes in the rear drums used for helping remove a drum? One of mine is completely stripped out on one side, and I have tried everything I have in stock on the other and nothing fits. I have backed off the adjusting screw, but the drum is stuck. The axle turns with no rubbing noise, so I don't think the brake is holding the drum on. And no, the emerg brake is off.
88 toy 4x4 truck, stock brakes <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: Rear Brake Drum Bolt [Re: Richards19884x4] #893197 06/28/08 04:01 PM
salvo Offline
take some spray lube and a file or sandpaper. Clean the center of the axle shaft that comes through the center of the brake drum they usually buld up corrosion and make it impossible to get teh drum off sometimes. A file usually works better as you can get right tight up to the drum. Then give it a light shot of lube and start wiggiling back and forth and it should start to come off.
Re: Rear Brake Drum Bolt [Re: Richards19884x4] #893198 06/28/08 05:52 PM
toyrunner Offline
I spray some lube on the axle center and tap it with a dead blow hammer till it comes off. Those threaded holes will only strip out again <img src="/forums/images/graemlins/baby.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5928 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-10-21 22:05:50 UTC
