replacement Toyota ball joints didn't last...anybody else? #893390 06/30/08 01:24 PM
TomPoh Offline OP
i replaced my upper and lower ball joints at 174K with Toyota parts. the replacements only lasted 75K miles...a major disappointment.
on the lift i noticed a lot of play in the driver's side wheel, and figured it was the original wheel bearings finally giving up. but i was surprised to see the lower ball joint moving quite a bit. the other wheel also has quite a bit of movement as well.
anybody else have replacement ball joint problems?
this now explains the vibration during braking. do you guys ever just replace the lower ball joints, and leave the uppers alone? I.e. do the lowers wear out faster?
thanks,
tom
95 T100 SR5 Xcab 4X4
Re: replacement Toyota ball joints didn't last...anybody else? [Re: TomPoh] #893391 06/30/08 06:24 PM
E
eleet Offline
All 4 of my originals died before 120k. I took them apart, they all have plastic bushings in them. Nothing you can do about that. Except find better ones or throw another $170 at toyota. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: replacement Toyota ball joints didn't last...anybody else? [Re: eleet] #893392 06/30/08 07:05 PM
TomPoh Offline OP
i guess my gripe was that the OEM replacemenets are obviously not the same quality as the originals. but perhaps i should have expected that since it seems common with GM parts outsourced overseas.
Re: replacement Toyota ball joints didn't last...anybody else? [Re: TomPoh] #893393 06/30/08 07:38 PM
E
eleet Offline
The ones I got from the dealer were made in Japan and as far as I could tell identical to the original parts. But I don't think they are worth $40+ each.
Some of the ones I looked at online from aftermarket sellers looked slightly different and they all cost more.
Did you get the ones that you're complaining about from the dealer or in the aftermarket?
Re: replacement Toyota ball joints didn't last...anybody else? [Re: eleet] #893394 07/01/08 04:39 AM
CJMT100 Offline
I got delco replacements, just did them at 193k. No idea if the previous owner did them, but they didnt look happy.
Re: replacement Toyota ball joints didn't last...anybody else? [Re: CJMT100] #893395 07/01/08 09:06 PM
TomPoh Offline OP
where did you buy the delco parts?
Re: replacement Toyota ball joints didn't last...anybody else? [Re: eleet] #893396 07/01/08 09:08 PM
TomPoh Offline OP
i bought them at the toyota dealership. i guess i need another set of 4 ball joints.
do the uppers or lower wear out sooner? if the lowers wear out faster, maybe i'll just leave the uppers alone. but i vaguely recall the uppers take more of the load?
Re: replacement Toyota ball joints didn't last...anybody else? [Re: TomPoh] #893397 07/02/08 04:02 AM
CJMT100 Offline
The shop I work at I had the boss order replacements, came in delco box. Same with my idler and pitman arm, delco parts.
Re: replacement Toyota ball joints didn't last...anybody else? [Re: TomPoh] #893398 07/03/08 06:45 PM
surlynkid Offline
the preferred replacement parts that last longer are the SAS pieces. <img src="/forums/images/graemlins/smile.gif" alt="" />
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: replacement Toyota ball joints didn't last...anybody else? [Re: surlynkid] #893399 07/03/08 11:11 PM
jroc Offline
Especially if the SAS'd truck just sits in the drive....... <img src="/forums/images/graemlins/nana.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6350 MB (Peak: 0.7419 MB) Data Comp: Off Server Time: 2026-07-09 19:01:09 UTC
