'86 igniter symptoms? #893669 07/01/08 03:37 PM
O
opusthe2nd Offline OP
Will the igniter just quit and never work again? My Sons truck is giving him a fit, and he is 120 miles from here. [By the way, anyone here in Kalispell?] It acts at times like it is flooded, yet it isnt. Sometimes it will start, other times it wont. It left him stranded last night but ran this morning. Trying to do what I can, from a distance.
Re: '86 igniter symptoms? [Re: opusthe2nd] #893670 07/01/08 04:36 PM
thxgoon Offline
Check the cable from the igniter to the distributer. I had a similar problem a few years ago. Acted like it was flooded, would start and puff black smoke, sometimes ran fine, sometimes not at all. Ended up that the connector on the wire was almost completely burnt off.
Re: '86 igniter symptoms? [Re: thxgoon] #893671 07/01/08 07:42 PM
dcg9381 Offline
The mag pick up in the distributor can cause a no-spark condition also.
22REturbo.net
1988 4Runner
Re: '86 igniter symptoms? [Re: dcg9381] #893672 07/02/08 06:06 AM
O
Or...would I be better going with the GM HEI conversion?
Re: '86 igniter symptoms? [Re: opusthe2nd] #893673 07/02/08 06:19 AM
kewlynx Offline
If it's not cranking AT ALL, and NO dash lights, have him check his fusible link at the pos battery terminal to make sure it didn't rot off.
**ubi apis- ibi salus**
Re: '86 igniter symptoms? [Re: kewlynx] #893674 07/02/08 03:44 PM
O
It always turns over. Just doesnt fire at times.
Re: '86 igniter symptoms? [Re: opusthe2nd] #893675 07/02/08 04:55 PM
4Crawler Offline
What sort of engine?
Re: '86 igniter symptoms? [Re: 4Crawler] #893676 07/02/08 05:09 PM
O
1986 22R
Re: '86 igniter symptoms? [Re: opusthe2nd] #893677 07/03/08 06:05 AM
W
whitetoy Offline
1986 22R
For about $20, he can get an igniter from a picknpull yard, and swap it in. Best way to diagnose. I always carry a spare, because they do occasionally die.
Rick
1984 4Runner
Re: '86 igniter symptoms? [Re: whitetoy] #893678 07/03/08 06:08 AM
O
Junk yard is 150 miles from here, they dont have any. I have been this route before, I am 99% sure this is the issue. I am going to go the GM HEI route I am thinking.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6389 MB (Peak: 0.7410 MB) Data Comp: Off Server Time: 2026-07-15 18:37:14 UTC
