Re: '86 igniter symptoms? [Re: opusthe2nd] #893679 07/03/08 06:54 AM
A
anotherjeff Offline
Many of us have spare igniters, purchased when we thought it was bad. (Ouch!)
Good luck!
Re: '86 igniter symptoms? [Re: anotherjeff] #893680 07/03/08 02:48 PM
O
opusthe2nd Offline OP
Hmmm...I'll bite, what is a "AFM/MAS (or TPS, for that matter)"?
Re: '86 igniter symptoms? [Re: opusthe2nd] #893681 07/03/08 04:38 PM
Staceman Offline
AFM -Air Flow Meter
MAS - Mass Airflow Sensor
TPS - Throttle Position Sensor
Used on Fuel Injected engines (22RE)
Not found on carbed motors.
Re: '86 igniter symptoms? [Re: Staceman] #893682 07/03/08 04:45 PM
Staceman Offline
Your problem does sound electrical.
I would remove the relay/fuse link box from the fenderwell and double check all wire ends and connections under there, (Dont forget to disconnect the battery first!) one gave me fits on my old 85 22R. Also double check all grounds in the engine compartment.
Re: '86 igniter symptoms? [Re: Staceman] #893683 07/03/08 04:49 PM
O
Ok, this is carbed.
Re: '86 igniter symptoms? [Re: Staceman] #893684 07/03/08 04:54 PM
O
There were 2 100+ degree days when this happened. Also, it has been running rich, which in this case would indicate not a complete burn due to poor spark. When its cool out, it runs a little better, as far as not quitting on him and having no spark.
I've had to replace this before, with a used part. I'm done paying such a high price for parts. This is why I am going to go the GM HEI route.
Re: '86 igniter symptoms? [Re: opusthe2nd] #893685 07/03/08 05:19 PM
Staceman Offline
The number one issue on the carbs is a AAP (Auxillary Air Pump). This is designed to add extra gas to the engine when cold, to help smooth out the idle. Is the #1 spark plug black, covered in soot? If the AAP goes bad, extra fuel will ALWAYS pour into the engine, causing it to run rich. Here is a quick easy test pic below:
Re: '86 igniter symptoms? [Re: Staceman] #893686 07/03/08 05:36 PM
O
Tailpipe is black, not sure on plugs but at this point they are probably all black. He is 120 miles from me, but I believe that hose is removed and plugged.
While talking on it, I would love to find a generic replacement carb. Wish there was something simple that would bolt up, aside from a Weber. Different topic, different time.
Re: '86 igniter symptoms? [Re: dcg9381] #893687 07/05/08 03:34 AM
sindersblue Offline
The mag pick up in the distributor can cause a no-spark condition also.
X2. I've never had a Yota pick up go bad but have seen em go haywire on Heeps and Fords.
It runs rich some times, not at all, or runs fine till it's up to temperature. Just a few that come to mind.
Good luck.
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project
87 Turbo Truck, Boost Controller, otherwise stock... for now.
86 Turbo 4Runner, Project
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6314 MB (Peak: 0.7361 MB) Data Comp: Off Server Time: 2026-11-03 11:40:52 UTC
