abs axle in an xj #893867 07/02/08 10:46 AM
E
el_d_m Offline OP
just got a 92 xj with a 3.5 prochump lift. has the d35 turd in the rear with anti lock brakes. i want to upgrade to either a 44 or a chrysler 8.25. should i be looking at grand cherokees? i have welders so thats not an issue.
any suggestions would be appreciated.
how about a ruby 44 rear? are they abs?
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: abs axle in an xj [Re: el_d_m] #893868 07/02/08 02:26 PM
DBL_DTY97TJ Offline
The easiest swap would be the 8.25 Chrysler out of another Cherokee. They were stock in a bunch of them. Don't know what years, but the GF's '01 has it.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: abs axle in an xj [Re: DBL_DTY97TJ] #893869 07/02/08 04:27 PM
superdawg Offline
97+ have 29 spline shafts, earlier are 27. 8.25
Earliers can be converted.
D44 is best, but hard tyo find.
88-90' only. and not a lot of them.
SD
Re: abs axle in an xj [Re: el_d_m] #893870 07/05/08 03:16 PM
E
el_d_m Offline OP
ok i got my hands on a couple of d44 out of xj's. both are 3.54 & open diffs. one is complete drums & the other is brakeless. what do i need to do to make the brakes work with my abs system? maybe a disc conversion?
or can you just put in an axle that has regualr brakes? or do they have to be antilock?
Re: abs axle in an xj [Re: el_d_m] #893871 07/06/08 04:53 AM
DBL_DTY97TJ Offline
They do not have to be discs. As far as I know it's all 'puter contolled form beyond. Discs would be the better option simply for maintenance, but that's about it. How it all needs to be hooked up....Beyond me.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6076 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-10-24 08:18:35 UTC
