diff #894350 07/07/08 06:08 AM
kiwilad Offline OP
hi
would anyone be able to tell me if a diff off a 88 c22 bighorn would fit my 88 2.8 ltr any help would be great
Re: diff [Re: kiwilad] #894351 07/07/08 08:13 PM
BigSwede Offline
I don't know what a C22 is, but here in the states there were 2 gear ratios available...most Troopers, including the 2.8Ls, had 4.56 gears...but a few with the big tire option had 4.77s, including most of the RS (short wheel base) models here. NZ versions might vary though...
Serenity now!
Re: diff [Re: BigSwede] #894352 07/07/08 10:30 PM
kiwilad Offline OP
cheers for the reply. both trucks are long wheel base one has the 2.2 litre and mine is the 2.8 probably worth a try? <img src="/forums/images/graemlins/notooth.gif" alt="" />h
Re: diff [Re: kiwilad] #894353 07/08/08 02:41 AM
W
Wareagle Offline
I think all 89-97 model year 2.6, 2.8 & 3.2l gas engined troopers came with 4.56 or 4.77 (rare) gears. Anything built in 87 and 88 may or may not be interchangeable since some came with the smaller engines and smaller axles. I think they were all 4.56, but they ring bolt counts may be 8 in front 10 in rear, 10 for front and rear, or 10 in front and 12 in rear.
Re: diff [Re: kiwilad] #894354 07/08/08 05:35 AM
Jim_Paget Offline
hi
I suspect that he is talking about the 2.8l DIESEL, but we will have to wait for him to respond back. As far as I know, the 2.8l GAS was only available in the U.S.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: diff [Re: Jim_Paget] #894355 07/08/08 07:16 AM
kiwilad Offline OP
thanks for the help i suspect wareagle may be right the diff i was going to buy is off the 2.2 diesel model that came out here (nz) in 88 my trucks the same model and year except the motor mine being a 4jb1? 2.8 ltr deisel
Re: diff [Re: kiwilad] #894356 07/14/08 10:58 PM
Matski Offline
In the UK the change over from the 8 bolt front and 10 bolt rear to the 10 bolt front and 12 bolt rear was 87 I believe. If they are the same year as you say they should share the same diff carriers. The ratios may be different but probably will be the same if the bighorn is a diesel. But this can be a good thing, provided you swap the both diffs!
I have petrol 4.56 diffs in my 89 Mk1 (was a 4JB1) in place of the stock 4.44 diesel diffs, compensating for the larger boots.
(apologise if I am telling granny how to suck eggs with the ratios)
1989 3.1 Isuzu Bighorn Hybrid
2" Lift with longer shocks
31.10.50R15 Recip Trials
Full 2.5" free flow stainless system
Front mount intercooler
Pump tuned
4.56 Diffs
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6167 MB (Peak: 0.6910 MB) Data Comp: Off Server Time: 2026-06-07 04:36:14 UTC
